Plugins 〉SunBurst
SunBurst
grafana-sunburst-panel
The sunburst panel is a multi-level pie chart. It can contain hierarchical data.
Features
Tooltip
Tooltip is shown on mouse over of each arch node. Tooltip of a node shows information about same-leveled nodes and its child nodes.
| Description | |
| sum | The value of a node. If the node has children, the value of the node means sum of the values of its children. |
| average | If the node has children, the value of the node means average of the values of its children. |
| rate | The rate against the value of parent node. |
Drill down
If you click an node in the graph, the graph transforms to zoom and show the child nodes.
Options
Link template
If link template isn't blank, tooltip contains a link with values of node and its ancectors. You can use $1, $2, $3 ... to add values to the link.
Nodes
You can specify fields' types of a node.
| Description | |
| Number | Add unit (%, $, bits/sec, ...) |
| String | Do nothing and just display. |
| Date | Convert numbers as unix timestamp to date text in specified format. |
Ex.)<br>
Supported datasources and formats
| Data source | TimeSeries | Table | Docs |
| ElasticSearch | OK | -- | OK |
| InfluxDB | OK | OK | -- |
| Sqldb (not released) | OK | OK | OK |
- Docs is the format returned by terms-aggregation in ElasticSearch.
License
Apache V2.0 License
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing SunBurst on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install SunBurst from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
