Plugins 〉Trend Panel
Developer
Snuids
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Panel
community
Trend Panel
  • Overview
  • Installation
  • Change log
  • Related content
Description
This grafana panel displays trend panels based on the data source most recent time aggregation. It is possible to tune the thresholds and to limit the number of graphics per line.
The plugin was tested with Elastic Search 7.0 as data source. The trend is computed between the last and previous date aggregation of the serie.
Screenshots
Showcase
Traffic Lights
Panel Options
Traffic Lights
Datasource
Traffic Lights
Installing Trend Panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Trend Panel from the commandline:
grafana-cli plugins install
Changelog
2.0.15 (Released)
Initial grafana release.
