title: "Trend Panel plugin for Grafana"
description: "Trend Panel. Trend Panel plugin for Grafana by Arnaud Marchand. Available in Grafana Cloud and self-managed Grafana. See install steps and the changelog."
> This is the Markdown version of https://grafana.com/grafana/plugins/snuids-trend-panel/
# Trend Panel
- Developer: Arnaud Marchand
- Version: 2.0.15
- [Installation](https://grafana.com/grafana/plugins/snuids-trend-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/snuids-trend-panel/changelog.md)
![Showcase](https://grafana.com/api/plugins/snuids-trend-panel/versions/2.0.15/images/media/Example.png)
![Config](https://grafana.com/api/plugins/snuids-trend-panel/versions/2.0.15/images/media/Config.png)
![Datasource](https://grafana.com/api/plugins/snuids-trend-panel/versions/2.0.15/images/media/Datasource.png)
# Description
This grafana panel displays trend panels based on the data source most recent time aggregation. It is possible to tune the thresholds and to limit the number of graphics per line.
The plugin was tested with Elastic Search 7.0 as data source. The trend is computed between the last and previous date aggregation of the serie.
# Screenshots
## Showcase
![Traffic Lights](https://raw.githubusercontent.com/snuids/grafana-trafficlights-panel/master/src/media/Example.png)
## Panel Options
![Traffic Lights](https://raw.githubusercontent.com/snuids/grafana-trafficlights-panel/master/src/media/Config.png)
## Datasource
![Traffic Lights](https://raw.githubusercontent.com/snuids/grafana-trafficlights-panel/master/src/media/Datasource.png)
