Plugins 〉Colored SVG Panel
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Colored SVG Panel
- Overview
- Installation
- Related content
SVG Panel
This panel dispays data as a colored svg using a customizable threshold. Compatible with Grafana 7.0+
Dashboard
Parameters
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Colored SVG Panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Colored SVG Panel from the commandline:
grafana-cli plugins install
