title: "Colored SVG Panel plugin for Grafana"
description: "A panel that displays values as colored svg images. Colored SVG Panel plugin for Grafana by Arnaud Marchand. See install steps and the changelog."
> This is the Markdown version of https://grafana.com/grafana/plugins/snuids-svg-panel/
# Colored SVG Panel
- Developer: Arnaud Marchand
- Version: 1.0.0
- [Installation](https://grafana.com/grafana/plugins/snuids-svg-panel/installation.md)
![Showcase Dashboard](https://grafana.com/api/plugins/snuids-svg-panel/versions/1.0.0/images/img/svg-screenshot-1.png)
![Showcase Details](https://grafana.com/api/plugins/snuids-svg-panel/versions/1.0.0/images/img/svg-screenshot-2.png)
# SVG Panel
This panel dispays data as a colored svg using a customizable threshold. Compatible with Grafana 7.0+
### Dashboard
![Screenshot](https://raw.githubusercontent.com/snuids/grafana-svg-panel/master/docs/svg-screenshot-1.png?raw=true "Screenshot")
### Parameters
![Screenshot](https://raw.githubusercontent.com/snuids/grafana-svg-panel/master/docs/svg-screenshot-2.png?raw=true "Screenshot")
