title: "Table with Column Grouping panel plugin for Grafana"
description: "Advanced table panel with support for multi-level column headers and flexible column… Table with Column Grouping panel plugin for Grafana by smelentyev."
> This is the Markdown version of https://grafana.com/grafana/plugins/smelentyev-tablecolumngrouping-panel/
# Table with Column Grouping
- Developer: smelentyev
- Version: 1.0.12
- [Installation](https://grafana.com/grafana/plugins/smelentyev-tablecolumngrouping-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/smelentyev-tablecolumngrouping-panel/changelog.md)
![Grouped audit events with test data](https://grafana.com/api/plugins/smelentyev-tablecolumngrouping-panel/versions/1.0.12/images/img/screenshots/table-main.png)
![Grouped table panel options](https://grafana.com/api/plugins/smelentyev-tablecolumngrouping-panel/versions/1.0.12/images/img/screenshots/table-edit-options.png)
![No data state](https://grafana.com/api/plugins/smelentyev-tablecolumngrouping-panel/versions/1.0.12/images/img/screenshots/table-no-data.png)
Table with Column Grouping is an advanced Grafana table panel that adds multi-level headers and flexible column grouping on top of the standard table experience.
## Features
- Multi-level column headers with nested group structures
- Vertical or horizontal grouping orientations
- Standard table features: sorting, filtering, column resizing
- Optional pagination for large datasets
- Field-based styling and cell display modes
## Requirements
- Grafana 11.6 or newer
## Getting Started
1. Add the panel to a dashboard and pick a data source/query.
2. Open **Table Display** and enable **Column Grouping**.
3. Build header groups in the visual editor.
4. Adjust column widths, alignment, and cell display modes in **Field** options.
## Documentation
- Repository: <https://github.com/Smelentyev/grafana-table-column-grouping>
- Issues: <https://github.com/Smelentyev/grafana-table-column-grouping/issues>
## Contributing
Pull requests and issue reports are welcome. Please include steps to reproduce and screenshots where possible.
