title: "3D Globe Panel plugin for Grafana"
description: "A Cesium based 3D Globe panel plugin. 3D Globe Panel plugin for Grafana by satellogic. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/satellogic-3d-globe-panel/
> The index of all catalog pages is at https://grafana.com/grafana/plugins/llms.txt
# 3D Globe Panel
- Developer: satellogic
- Version: 0.1.1
- [Installation](https://grafana.com/grafana/plugins/satellogic-3d-globe-panel/installation.md)
![Globe View](https://grafana.com/api/plugins/satellogic-3d-globe-panel/versions/0.1.1/images/img/screenshots/globe.png)
![Spread View](https://grafana.com/api/plugins/satellogic-3d-globe-panel/versions/0.1.1/images/img/screenshots/spread.png)
A _[Cesium.js](http://cesiumjs.org/)_ based 3D Globe panel, with some customization options. Just define your CZML datasource in the options section and the panel will render it.
You can use any template variable you defined in your dashboard as part of the Querystring or Base URL, with two extra variables replaced by the plugin:
- `$timeFrom`: Unix timestamp with the start of the currently selected time range
- `$timeTo`: Unix timestamp with the end of the currently selected time range
