title: "Astro Theme panel plugin for Grafana"
description: "An Astro UXDS theme for Grafana dashboards. Astro Theme panel plugin for Grafana by rocketcom. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/rocketcom-astrotheme-panel/
# Astro Theme
- Developer: rocketcom
- Version: 1.1.1
- [Installation](https://grafana.com/grafana/plugins/rocketcom-astrotheme-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/rocketcom-astrotheme-panel/changelog.md)
![Panel with clock and theme picker](https://grafana.com/api/plugins/rocketcom-astrotheme-panel/versions/1.1.1/images/img/screenshots/full.png)
![Light theme panel with clock and theme picker](https://grafana.com/api/plugins/rocketcom-astrotheme-panel/versions/1.1.1/images/img/screenshots/full-light-theme.png)
![Creating Astro Theme panel](https://grafana.com/api/plugins/rocketcom-astrotheme-panel/versions/1.1.1/images/img/screenshots/NewPanelMenu.png)
![Panel next to themed nav](https://grafana.com/api/plugins/rocketcom-astrotheme-panel/versions/1.1.1/images/img/screenshots/PanelNextToNav.png)
## About This Plugin
This panel plugin is primarly a theme plugin. It provides CSS style overrides for the Grafana dashboard in order to theme the dashboard with the [Astro UXDS](https://www.astrouxds.com/) design system. It also provides options for a classification banner, clock, light/dark theme switching, and setting a default theme. The Astro Panel _must_ be added to a dashboard in order for styles to take effect. Navigation inside of the Grafana dashboard will retain the plugin's overrides, but moving away from the dashboard will cause the styles to revert back to Grafana defaults.
## Panel Options
- Default theme
  - Sets the default theme that the dashboard will use.
- Hide Theme Picker
  - Hides the light/dark button that provides theme switching.
- Classification Banner
  - Provides all clearance level classfication banners at the top of the Astro panel.
- Include Clock
  - Shows or hides the clock.
- Format
  - Allows user to choose left, center, or right alignment for the panel content.
- Hide Astro Panel
  - Hides the Astro Panel from the dashboard, but retains the style overrides the panel provdies.
## MIL-STD 1472 Compliance
The Astro plugin for Grafana implements the AstroUX Design System and implements requirements for Section 5.17 of MIL-STD 1472 compliance as documented at <https://www.astrouxds.com/compliance/mil-std-1472/> the Astro plugin does not impact or account for core Grafana functionality. No review of Grafana’s core functionality is implied or warranted by this statement. Any user generated content is not implied or warranted. It is the responsibility of implementors and 3rd party tools to evaluate and implement any 1472 compliance. For questions or comments please contact <support@astrouxds.com>.
## Support
For any issues or ideas, please see [the github page](https://github.com/RocketCommunicationsInc/grafana-theme).
