title: "Pyroscope Flamegraph panel plugin for Grafana"
description: "Pyroscope plugin for grafana. Pyroscope Flamegraph panel plugin for Grafana by pyroscope. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/pyroscope-panel/
# Pyroscope Flamegraph
- Developer: pyroscope
- Version: 1.4.2
- [Change log](https://grafana.com/grafana/plugins/pyroscope-panel/changelog.md)
# Pyroscope Grafana Panel Plugin
**Important: Grafana version 8.0 or later required**
## Getting started
1. Install the plugin (Installation tab)
2. Install [datasource plugin](https://grafana.com/grafana/plugins/pyroscope-datasource/)
3. Open Grafana and go to **Configuration -> Plugins**
4. Check that plugins are available
5. Set up data source plugin:
   - **Configuration -> Data Sources -> Add data source**
   - click on `pyroscope-datasource`
   - Specify Pyroscope host in `Endpoint` field
6. Set up panel plugin:
   - Add an empty panel on your dashboard
   - Select `pyroscope-panel` from Visualization list
   - Under panel view in Query tab select `pyroscope-datasource`
   - In `Application name` input specify app name
   - Click `Apply`
Congratulations! Now you can monitor application flamegraph on your Grafana dashboard!
