title: "TrackMap panel plugin for Grafana"
description: "A panel that visualizes GPS points as a line on an interactive map. TrackMap panel plugin for Grafana by pr0ps. See install steps and the changelog."
> This is the Markdown version of https://grafana.com/grafana/plugins/pr0ps-trackmap-panel/
# TrackMap
- Developer: pr0ps
- Version: 3.0.2
- [Installation](https://grafana.com/grafana/plugins/pr0ps-trackmap-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/pr0ps-trackmap-panel/changelog.md)
![Show current selection as a dot on the map](https://grafana.com/api/plugins/pr0ps-trackmap-panel/versions/3.0.2/images/img/topo-crosshair.jpg)
![Zoom in by selecting a range of points](https://grafana.com/api/plugins/pr0ps-trackmap-panel/versions/3.0.2/images/img/topo-boxselect.jpg)
![Chose what map to display the data on](https://grafana.com/api/plugins/pr0ps-trackmap-panel/versions/3.0.2/images/img/satellite-picker.jpg)
# TrackMap Panel for Grafana
[![Marketplace](https://img.shields.io/badge/dynamic/json?logo=grafana\&query=$.version\&url=https://grafana.com/api/plugins/pr0ps-trackmap-panel\&label=Marketplace\&prefix=v\&color=F47A20)](https://grafana.com/grafana/plugins/pr0ps-trackmap-panel/) ![Required grafana version](https://img.shields.io/badge/dynamic/json?logo=grafana\&query=$.grafanaDependency\&url=https://grafana.com/api/plugins/pr0ps-trackmap-panel\&label=Grafana\&color=F47A20) ![Downloads](https://img.shields.io/badge/dynamic/json?logo=grafana\&query=$.downloads\&url=https://grafana.com/api/plugins/pr0ps-trackmap-panel\&label=Downloads)
A panel for [Grafana](https://grafana.com/) that visualizes GPS points as a line on an interactive map.
## Features
- Places a dot on the map at the current time as you mouse over other panels.
- Zoom to a range of points by drawing a box by shift-clicking and dragging.
- Multiple map backgrounds: [OpenStreetMap](https://www.openstreetmap.org/), [OpenTopoMap](https://opentopomap.org/), and [Satellite imagery](https://www.esri.com/).
- Track and dot colors can be customized in the options tab.
## Configuration
The plugin requires latitude and longitude measurements provided as numbers in two separate fields. These can be formatted as "Time series" or "Table" data by Grafana. The order of the data returned by the query is required (latitude, then longitude) since the labels and tag names are not used.
For example, the following query has been tested using InfluxDB as a data source in the case where the `latitude` and `longitude` series are stored in the `location` measurement:
SELECT median("latitude"), median("longitude") FROM "location" WHERE $timeFilter GROUP BY time($__interval)
Because the plugin only cares about getting 2 series of data, it's also possible to use MySQL/MariaDB as a data source by using 2 queries like so:
A: SELECT "latitude" as value, $__time(timestamp) FROM "location" WHERE $__timeFilter(timestamp) ORDER BY timestamp ASC
B: SELECT "longitude" as value, $__time(timestamp) FROM "location" WHERE $__timeFilter(timestamp) ORDER BY timestamp ASC
