title: "Parca Flamegraph panel plugin for Grafana"
description: "Parca panel plugin for Grafana. Parca Flamegraph panel plugin for Grafana by Parca Dev. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/parca-panel/
# Parca Flamegraph
- Developer: Parca Dev
- Version: 0.0.36
- [Installation](https://grafana.com/grafana/plugins/parca-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/parca-panel/changelog.md)
![Parca Flamegraph](https://grafana.com/api/plugins/parca-panel/versions/0.0.36/images/img/screenshots/panel.png)
![Parca Flamegraph Config](https://grafana.com/api/plugins/parca-panel/versions/0.0.36/images/img/screenshots/panel-config.png)
# Parca Flamegraph Plugin for Grafana
## Getting started
1. Install the Parca flamegraph plugin from the [Grafana plugin repository](https://grafana.com/grafana/plugins/parca-panel/).
2. Make sure that Parca datasource plugin is installed and configured in Grafana, if not, follow the instructions [here](#configuring-the-datasource).
3. Configure the Parca flamegraph panel:
   1. Add a new panel to your dashboard.
   2. In the Query section:
      1. Select the Parca datasource.
      2. The `Profile Type` dropdown, lists the profile types that are available on the connected Parca server. Select the profile type you want to visualize.
      3. In the `Query Selector` field, enter the query you want to visualize. The query selector is a [PromQL](https://prometheus.io/docs/prometheus/latest/querying/basics/) like expression that is used to select the profiles that you want to visualize. For example, `{job="api-server"}` will select all the profiles that have the label `job` with the value `api-server`.
   3. In the Visualization section on the right, select the `Parca Flamegraph` visualization. Now you should be able to see the flamegraph visualization, for the selected query.
   4. Enter a suitable title for the panel in the `Panel Title` field.
   5. Save the Panel.
## Configuring the Datasource
1. Install the Parca datasource plugin from the [Grafana plugin repository](https://grafana.com/grafana/plugins/parca-datasource/).
2. In the Grafana UI, navigate to the `Configuration` -> `Data Sources` page.
3. Click on the `Add data source` button.
4. Select the `Parca` datasource.
5. Enter the API URL of the Parca server in the `API Endpoint` field. For example, `http://localhost:7070/api`. Note: Please make sure cors configuration of the Parca server allow requests from your Grafana Dashboard origin. If you Grafana dashboard is running at `http://localhost:3000`, then ensure that the Parca server is started with either `--cors-allowed-origins='http://localhost:3000'` or `--cors-allowed-origins='\*'` flag. Please refer the [docs](https://www.parca.dev/docs/grafana-datasource-plugin#allow-cors-requests).
6. Click on the `Save & Test` button. If the connection is successful, you should see a green `Data source is working` message.
7. Now you can use the Parca datasource in your panels.
## Screenshots
![Parca Flamegraph](https://raw.githubusercontent.com/parca-dev/parca/main/ui/packages/app/grafana-panel-plugin/src/img/screenshots/panel.png) ![Parca Flamegraph Config](https://raw.githubusercontent.com/parca-dev/parca/main/ui/packages/app/grafana-panel-plugin/src/img/screenshots/panel-config.png)
