title: "Orchestra Cities Map panel plugin for Grafana"
description: "Orchestra Cities Map. Orchestra Cities Map panel plugin for Grafana by Orchestra Cities by Martel. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/orchestracities-map-panel/
# Orchestra Cities Map
- Developer: Orchestra Cities by Martel
- Version: 1.4.4
- [Installation](https://grafana.com/grafana/plugins/orchestracities-map-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/orchestracities-map-panel/changelog.md)
![Example](https://grafana.com/api/plugins/orchestracities-map-panel/versions/1.4.4/images/img/example.png)
![IDW Interpolation](https://grafana.com/api/plugins/orchestracities-map-panel/versions/1.4.4/images/img/idw.png)
![Configuration Options](https://grafana.com/api/plugins/orchestracities-map-panel/versions/1.4.4/images/img/options.png)
![Popup example](https://grafana.com/api/plugins/orchestracities-map-panel/versions/1.4.4/images/img/popup.png)
# Orchestra Cities - Map Panel
This plugin extends [Grafana Geomap](https://grafana.com/docs/grafana/latest/visualizations/geomap/) panel with several functionalities:
- Support for GeoJSON shapes
- Support for icons (icons supported are from [FontAwesome](https://fontawesome.com/))
- Support for pop up visualizations of data from a specific point
- Multiple layers for the different queries
- A new map layer leveraging [Inverse distance weighting](https://en.wikipedia.org/wiki/Inverse_distance_weighting) (IDW) interpolation for scattered data points using Shepard's method.
![Marker layer](https://github.com/orchestracities/grafana-map-plugin/raw/master/example.png)
![IDW layer](https://github.com/orchestracities/grafana-map-plugin/raw/master/example4.png)
New customization options available for the markers layer:
- Cluster support with a lot of customization like distance and value to display
- A fully customizable pin with the possibility to change colors, shapes and sizes
- The possibility to select which properties to be displayed on the popup
![Marker layer options](https://github.com/orchestracities/grafana-map-plugin/raw/master/example2.png)
Cluster options:
- Distance
- Min distance
Pin Options:
- Shape
- Size
- Customizable icon
- Shadow
- Gradient
Popup Options:
- Display a title
- Display the Timestamp
- Selectable properties
![Marker layer options](https://github.com/orchestracities/grafana-map-plugin/raw/master/example3.png)
Options available for the IDW layer:
IDW options:
- Weight value to be used to create the interpolation, including min and max range
- Scale factor of the precision of the interpolation
- Show data values over the map
Pupup Options:
- Display a title
![Marker layer options](https://github.com/orchestracities/grafana-map-plugin/raw/master/example5.png)
It requires Grafana >=8.2.0
## Usage with PostGis
To use the plugin with PostGis, you need either to query longitude and latitude from a stored `Point`, e.g.:
- `ST_X(ST_GeomFromEWKT(location_centroid)) AS \"longitude\"`
- `ST_Y(ST_GeomFromEWKT(location_centroid)) AS \"latitude\"`
Or query the GeoJSON shape, e.g.:
- `ST_AsGeoJSON(ST_GeomFromEWKT(location)) AS \"geojson\"`
## Usage with CrateDB
To use the plugin with CrateDB, you need either to query longitude and latitude from a stored `Point`, e.g.:
- `longitude(location_centroid) AS \"longitude\"`
- `latitude(location_centroid) AS \"latitude\"`
Or query the GeoJSON field, e.g.:
- `location AS \"geojson\"`
## What is a Grafana Panel Plugin?
Panels are the building blocks of Grafana. They allow you to visualize data in different ways. While Grafana has several types of panels already built-in, you can also build your own panel, to add support for other visualizations.
For more information about panels, refer to the documentation on [Panels](https://grafana.com/docs/grafana/latest/features/panels/panels/)
## Set up dev environment
See [Contributing](https://github.com/orchestracities/grafana-map-plugin/blob/master/CONTRIBUTING.md)
