title: "Orchestra Cities Icon Stat Panel plugin for Grafana"
description: "Orchestra Cities Icon Stat Panel plugin for Grafana by Orchestra Cities by Martel. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/orchestracities-iconstat-panel/
# Orchestra Cities Icon Stat Panel
- Developer: Orchestra Cities by Martel
- Version: 1.2.3
- [Installation](https://grafana.com/grafana/plugins/orchestracities-iconstat-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/orchestracities-iconstat-panel/changelog.md)
![example](https://grafana.com/api/plugins/orchestracities-iconstat-panel/versions/1.2.3/images/img/example.png)
# Orchestra Cities - Icon Stat Panel
This plugin extends Grafana Stat panel with icons support. More info at <https://grafana.com/docs/grafana/latest/visualizations/stat-panel/>
Icons supported are from [FontAwesome](https://fontawesome.com/)
![Example](https://raw.githubusercontent.com/orchestracities/statistics-panel/master/src/img/example.png)
Options available:
- Icon selection
- Icon position selection (title or value)
- Custom title
- Custom prefix
- Custom suffix (will be combined with the unit if present)
- Trend (it displays an arrow showing the trend of the data)
![Options](https://raw.githubusercontent.com/orchestracities/statistics-panel/master/options.png)
It requires Grafana >=8.2.0
## What is Grafana Panel Plugin?
Panels are the building blocks of Grafana. They allow you to visualize data in different ways. While Grafana has several types of panels already built-in, you can also build your own panel, to add support for other visualizations.
For more information about panels, refer to the documentation on [Panels](https://grafana.com/docs/grafana/latest/features/panels/panels/)
## Set up dev environment
See [Contributing](https://github.com/orchestracities/iconstat-panel/blob/master/CONTRIBUTING.md)
