title: "Grafmaid panel plugin for Grafana"
description: "Render Mermaid.js diagrams in Grafana with live data from queries, dashboard variables, and threshold-based styling. See install steps and the changelog."
> This is the Markdown version of https://grafana.com/grafana/plugins/neildengg-grafmaid-panel/
# Grafmaid
- Developer: neildengg
- Version: 1.0.6
- [Change log](https://grafana.com/grafana/plugins/neildengg-grafmaid-panel/changelog.md)
![Basic diagrams - Flowchart, Sequence, State](https://grafana.com/api/plugins/neildengg-grafmaid-panel/versions/1.0.6/images/img/basic-graph-1.png)
![Advanced diagrams - Class, Journey, ER, Quadrant, Pie](https://grafana.com/api/plugins/neildengg-grafmaid-panel/versions/1.0.6/images/img/basic-graph-2.png)
![Git Graph, C4 Component, Packet](https://grafana.com/api/plugins/neildengg-grafmaid-panel/versions/1.0.6/images/img/basic-graph-3.png)
![Dashboard Variables integration](https://grafana.com/api/plugins/neildengg-grafmaid-panel/versions/1.0.6/images/img/variables.png)
![Data Queries with threshold coloring](https://grafana.com/api/plugins/neildengg-grafmaid-panel/versions/1.0.6/images/img/queries.png)
![Grafmaid Logo](https://raw.githubusercontent.com/neildeng/grafana-grafmaid/main/src/img/logo.svg)
**Gra**fana + Mer**maid**.js = **Grafmaid**
A Grafana panel plugin that renders [Mermaid.js](https://mermaid.js.org/) diagrams with live data from queries, dashboard variables, and threshold-based styling — turning static architecture diagrams into dynamic, data-driven visuals.
[![License](https://img.shields.io/github/license/neildeng/grafana-grafmaid)](https://github.com/neildeng/grafana-grafmaid/blob/main/LICENSE) [![GitHub release](https://img.shields.io/github/v/release/neildeng/grafana-grafmaid)](https://github.com/neildeng/grafana-grafmaid/releases)
## Screenshots
![Flowchart, Sequence, State diagrams](https://raw.githubusercontent.com/neildeng/grafana-grafmaid/main/src/img/basic-graph-1.png)
![Dashboard Variables integration](https://raw.githubusercontent.com/neildeng/grafana-grafmaid/main/src/img/variables.png)
![Data Queries with threshold coloring](https://raw.githubusercontent.com/neildeng/grafana-grafmaid/main/src/img/queries.png)
## Features
- **All Mermaid diagram types** — Flowchart, Sequence, Class, State, ER, Gantt, Pie, Mindmap, Timeline, Git Graph, C4, and more
- **Dashboard Variables** — Use `$variable` / `${variable}` syntax and `{{#each var}}` multi-value expansion
- **Data Queries** — Inject live metric values via `${__data.CPU_A:display}` shorthand or `${__data.fields.X}` full syntax
- **Labels** — Access metric labels with `${__data.CPU_A.labels.http_status}`
- **Field Config** — Standard Options support: Units, Thresholds, Value Mappings, Color scheme, Decimals
- **Threshold coloring** — Color diagram nodes dynamically based on threshold values using `${__data.CPU_A:color}`
- **Special character escaping** — Auto-escape `[ ] { } | > <` in variable values to prevent syntax errors
- **Theme-aware** — Auto-switches Mermaid theme based on Grafana dark/light mode
- **Responsive** — SVG diagrams auto-scale with panel dimensions
## Requirements
- Grafana >= 12.3.0
## Getting Started
1. Install the plugin from the Grafana plugin catalog
2. Add a new panel and select **Grafmaid** as the visualization
3. Write your Mermaid diagram in the **Mermaid Content** option
4. (Optional) Configure data source queries to inject live values
## Configuration
### Panel Options
| Option                    | Default           | Description                                             |
| Mermaid Content           | Example flowchart | Mermaid diagram definition with variable/data syntax    |
| Escape special characters | `true`            | Auto-escape Mermaid special characters in values        |
| Max data rows             | `100`             | Max rows for `{{#each data}}` expansion (0 = unlimited) |
### Standard Options
The panel supports Grafana Standard Options via Field Config:
- **Unit** — Format numeric values (percent, bytes, etc.)
- **Thresholds** — Define color breakpoints (default: green base, red at 80)
- **Value Mappings** — Map values to custom text
- **Color scheme** — Defaults to "From thresholds (by value)"
- **Decimals** — Control decimal precision
### Data Syntax Quick Reference
| Syntax                                  | Description                                   |
| `$variable`                             | Dashboard variable substitution               |
| `{{#each var}}...{{value}}...{{/each}}` | Multi-value variable expansion                |
| `${__data.CPU_A:display}`               | Formatted value from query (auto value field) |
| `${__data.CPU_A:color}`                 | Threshold color from query                    |
| `${__data.CPU_A.labels.server}`         | Metric label value                            |
| `${__data.fields.Value}`                | Explicit field access from series\[0]         |
| `{{#each data.CPU_A}}...{{/each}}`      | Iterate over query rows                       |
### Example: Threshold-colored Diagram
graph LR
    A["${__data.CPU_A.labels.server}"] --> B["CPU: ${__data.CPU_A:display}"]
    style B fill:${__data.CPU_A:color},color:#fff
## Documentation
For detailed documentation, see [docs/README.md](https://github.com/neildeng/grafana-grafmaid/blob/main/docs/README.md).
## Contributing
- **Report bugs**: [GitHub Issues](https://github.com/neildeng/grafana-grafmaid/issues)
- **Feature requests**: [GitHub Issues](https://github.com/neildeng/grafana-grafmaid/issues)
- **Source code**: [GitHub Repository](https://github.com/neildeng/grafana-grafmaid)
## License
Apache License 2.0 — see [LICENSE](https://github.com/neildeng/grafana-grafmaid/blob/main/LICENSE).
## Third-Party Notices
This plugin bundles the following open-source software:
| Package                                          | License               | Copyright                    |
| [mermaid](https://github.com/mermaid-js/mermaid) | MIT                   | © 2014-2022 Knut Sveidqvist  |
| [dagre-d3-es](https://github.com/tbo47/dagre-es) | MIT                   | © 2013 Chris Pettitt         |
| [dayjs](https://github.com/iamkun/dayjs)         | MIT                   | © 2018-present iamkun        |
| [lodash-es](https://github.com/lodash/lodash)    | MIT                   | © OpenJS Foundation          |
| [marked](https://github.com/markedjs/marked)     | MIT                   | © 2018+ MarkedJS             |
| [roughjs](https://github.com/rough-stuff/rough)  | MIT                   | © 2019 Preet Shihn           |
| [KaTeX](https://github.com/KaTeX/KaTeX)          | MIT                   | © 2013-2020 Khan Academy     |
| [stylis](https://github.com/thysultan/stylis)    | MIT                   | © 2016-present Sultan Tarimo |
| [uuid](https://github.com/uuidjs/uuid)           | MIT                   | © 2010-2020 Robert Kieffer   |
| [DOMPurify](https://github.com/cure53/DOMPurify) | MPL-2.0 OR Apache-2.0 | © 2024 Cure53                |
Full license texts are available in the [NOTICES](https://github.com/neildeng/grafana-grafmaid/blob/main/NOTICES) file.
## Version
1.0.6 (built on 2026-04-06)
