title: "Plotly panel plugin for Grafana"
description: "Scatter plots and more. Plotly panel plugin for Grafana by Natel Energy. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/natel-plotly-panel/
# Plotly
- Developer: Natel Energy
- Version: 0.0.7
- [Installation](https://grafana.com/grafana/plugins/natel-plotly-panel/installation.md)
![Scatter](https://grafana.com/api/plugins/natel-plotly-panel/versions/0.0.7/images/img/screenshot-scatter.png)
![Scatter 2D](https://grafana.com/api/plugins/natel-plotly-panel/versions/0.0.7/images/img/screenshot-scatter-1.png)
![Scatter 3D](https://grafana.com/api/plugins/natel-plotly-panel/versions/0.0.7/images/img/screenshot-scatter-3d.png)
![Options](https://grafana.com/api/plugins/natel-plotly-panel/versions/0.0.7/images/img/screenshot-options.png)
## Plot.ly Panel for Grafana
[![CircleCI](https://circleci.com/gh/NatelEnergy/grafana-plotly-panel/tree/master.svg?style=svg)](https://circleci.com/gh/NatelEnergy/grafana-plotly-panel/tree/master) [![dependencies Status](https://david-dm.org/NatelEnergy/grafana-plotly-panel/status.svg)](https://david-dm.org/NatelEnergy/grafana-plotly-panel) [![devDependencies Status](https://david-dm.org/NatelEnergy/grafana-plotly-panel/dev-status.svg)](https://david-dm.org/NatelEnergy/grafana-plotly-panel?type=dev)
Render metrics using the plot.ly javascript framework
Works with grafana 4, 5, and 6
### Screenshots
![Screenshot of scatter plot](https://raw.githubusercontent.com/NatelEnergy/grafana-plotly-panel/master/src/img/screenshot-scatter.png) ![Screenshot of scatter plot](https://raw.githubusercontent.com/NatelEnergy/grafana-plotly-panel/master/src/img/screenshot-single-trace.png?raw=true) ![Screenshot of scatter plot](https://raw.githubusercontent.com/NatelEnergy/grafana-plotly-panel/master/src/img/screenshot-multiple-trace.png) ![Screenshot of 3d scatter plot](https://raw.githubusercontent.com/NatelEnergy/grafana-plotly-panel/master/src/img/screenshot-scatter-3d.png) ![Screenshot of the options screen](https://raw.githubusercontent.com/NatelEnergy/grafana-plotly-panel/master/src/img/screenshot-options-new.png)
### Building
To complie, run:
npm install -g yarn
yarn install --pure-lockfile
yarn build
### Releasing
This plugin uses [release-it](https://github.com/webpro/release-it) to release to GitHub.
env GITHUB_TOKEN=your_token yarn release-it patch
#### Changelog
##### v0.0.6
- Fix axis range configuration bug [#49](https://github.com/NatelEnergy/grafana-plotly-panel/issues/49)
- Add basic annotations support #57 (tchernobog)
- Improve loading times for plotly.js and support loading from CDN
- Assume date x-axis when 'auto' and the mapping has 'time'
- Support Fixed-Ratio Axes
- Tested with Grafana 6
##### v0.0.5
- Upgrade plotly (v1.41+)
- Better support for light theme. (#24, @cscheuermann81)
- Support snapshots
- Removing `dist` from master branch
- Support of multiple time series's ([#9](https://github.com/NatelEnergy/grafana-plotly-panel/issues/9), [CorpGlory DevTeam](https://corpglory.com/))
- Support showing text from query (#11)
- Template variable support
- Improved metric mapping
- Using webpack and basic jest tests
##### v0.0.4
- Load plotly from npm (v1.31.2+)
- Convert to TypeScript
- Reasonable behavior when adding single metric
- Formatting with prettier.js
- Support for a single table query
##### v0.0.3
- Improve options UI
- Added range mode: "tozero" and "nonnegative"
- Map metrics to X,Y,Z and color
- Can now select 'date' type for each axis to support time
- basic support to size marker with data
##### v0.0.2
- Added ability to set color from a metric query. (#4, @lzgrablic01)
- Show 3D axis names properly
- Fix initalization to work with 4.2+ (isPanelVisible undefined)
##### v0.0.1
- First working version
### Wishlist (help wanted)
- sizeref helper. I think this depends on the data. likely need to find the range and pick a good value? From react?
- nice to have: <https://plot.ly/javascript/parallel-coordinates-plot/>
