title: "Influx Admin panel plugin for Grafana"
description: "InfluxDB admin for grafana. Influx Admin panel plugin for Grafana by Natel Energy. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/natel-influx-admin-panel/
# Influx Admin
- Developer: Natel Energy
- Version: 0.0.6
- [Installation](https://grafana.com/grafana/plugins/natel-influx-admin-panel/installation.md)
![Current Queries](https://grafana.com/api/plugins/natel-influx-admin-panel/versions/0.0.6/images/img/screenshot-current.png)
![Kill Query](https://grafana.com/api/plugins/natel-influx-admin-panel/versions/0.0.6/images/img/screenshot-kill.png)
![Query Window](https://grafana.com/api/plugins/natel-influx-admin-panel/versions/0.0.6/images/img/screenshot-query.png)
![Options](https://grafana.com/api/plugins/natel-influx-admin-panel/versions/0.0.6/images/img/screenshot-options.png)
![Write Data](https://grafana.com/api/plugins/natel-influx-admin-panel/versions/0.0.6/images/img/screenshot-write.png)
## InfluxDB admin
This panel duplicates features from the now depricated [Web Admin Interface](https://docs.influxdata.com/influxdb/v1.2/tools/web_admin/).
This panel lets you see the currently running queries and easily kill them.
This plugin expects there to be at least one InfluxDB datasource configured.
### Screenshots
![Current Queries](https://raw.githubusercontent.com/NatelEnergy/grafana-influx-admin/master/src/img/screenshot-current.png) ![Kill Queries](https://raw.githubusercontent.com/NatelEnergy/grafana-influx-admin/master/src/img/screenshot-kill.png) ![Query Window](https://raw.githubusercontent.com/NatelEnergy/grafana-influx-admin/master/src/img/screenshot-query.png) ![Options](https://raw.githubusercontent.com/NatelEnergy/grafana-influx-admin/master/src/img/screenshot-options.png) ![Write Data](https://raw.githubusercontent.com/NatelEnergy/grafana-influx-admin/master/src/img/screenshot-write.png)
### Building
To complie, run:
npm install -g yarn
yarn install --pure-lockfile
grunt
#### Changelog
##### v0.0.5
- Now supports $timeFilter in query
- Now supports datasource defined as a template variable
- Added more debug query templates
- Fix write request bug
- Support Grafana 5+
##### v0.0.4
- Fix issue always showing query results
- When there is only one row, swap rows/cols (ie: SHOW DIAGNOSTICS)
- Improve auto-refresh behavior.
- Show 'message' response. (ie: please use POST)
- Fix query time sorting
- show 'status' field (killed, etc)
##### v0.0.3
- Converted to typescript project based on [typescript-template-datasource](https://github.com/grafana/typescript-template-datasource)
- Select Databases. This only works with [PR#8096](https://github.com/grafana/grafana/pull/8096)
- Added time format options
- Show tags from response
- Support template variables in the query
##### v0.0.2
- Save the configuration properly
##### v0.0.1
- First working version
