title: "Discrete panel plugin for Grafana"
description: "Discrete Events grafana. Discrete panel plugin for Grafana by Natel Energy. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/natel-discrete-panel/
# Discrete
- Developer: Natel Energy
- Version: 0.1.1
- [Change log](https://grafana.com/grafana/plugins/natel-discrete-panel/changelog.md)
![Single State](https://grafana.com/api/plugins/natel-discrete-panel/versions/0.1.1/images/img/screenshot-single-1.png)
![Tooltips](https://grafana.com/api/plugins/natel-discrete-panel/versions/0.1.1/images/img/screenshot-single-2.png)
![Summary Tooltips](https://grafana.com/api/plugins/natel-discrete-panel/versions/0.1.1/images/img/screenshot-single-3.png)
![Show all values](https://grafana.com/api/plugins/natel-discrete-panel/versions/0.1.1/images/img/screenshot-single-4.png)
![Multiple Results](https://grafana.com/api/plugins/natel-discrete-panel/versions/0.1.1/images/img/screenshot-multiple.png)
![Options](https://grafana.com/api/plugins/natel-discrete-panel/versions/0.1.1/images/img/screenshot-options-1.png)
![Legend](https://grafana.com/api/plugins/natel-discrete-panel/versions/0.1.1/images/img/screenshot-options-2.png)
## Discrete Panel
[![CircleCI](https://circleci.com/gh/NatelEnergy/grafana-discrete-panel/tree/master.svg?style=svg)](https://circleci.com/gh/NatelEnergy/grafana-discrete-panel/tree/master) [![dependencies Status](https://david-dm.org/NatelEnergy/grafana-discrete-panel/status.svg)](https://david-dm.org/NatelEnergy/grafana-discrete-panel) [![devDependencies Status](https://david-dm.org/NatelEnergy/grafana-discrete-panel/dev-status.svg)](https://david-dm.org/NatelEnergy/grafana-discrete-panel?type=dev)
This panel shows discrete values in a horizontal graph. This lets show state transitions clearly. It is a good choice to display string or boolean data
### Screenshots
![example](https://raw.githubusercontent.com/NatelEnergy/grafana-discrete-panel/master/src/img/screenshot-multiple.png) ![example](https://raw.githubusercontent.com/NatelEnergy/grafana-discrete-panel/master/src/img/screenshot-single-1.png) ![example](https://raw.githubusercontent.com/NatelEnergy/grafana-discrete-panel/master/src/img/screenshot-single-2.png) ![example](https://raw.githubusercontent.com/NatelEnergy/grafana-discrete-panel/master/src/img/screenshot-single-3.png) ![example](https://raw.githubusercontent.com/NatelEnergy/grafana-discrete-panel/master/src/img/screenshot-single-4.png) ![options](https://raw.githubusercontent.com/NatelEnergy/grafana-discrete-panel/master/src/img/screenshot-options-1.png) ![options](https://raw.githubusercontent.com/NatelEnergy/grafana-discrete-panel/master/src/img/screenshot-options-2.png)
### Building
To complie, run:
yarn install
yarn build
### Releasing
This plugin uses [release-it](https://github.com/webpro/release-it) to release to GitHub.
env GITHUB_TOKEN=your_token yarn release-it patch
### Roadmap
- TODO: full annotation support
- TODO: better documentation
- release v1.0
#### Changelog
##### v0.1.0
- works with Grafana 7 (naming fixed)
- Building with `@grafana/toolkit`
- Supports DataFrame directly for 6.4+
##### v0.0.9
- Remove `dist` from master
- Use webpack build
- FIX: Use background color to clear the background
- Configurable duration resolution option (thanks @clink-aaron)
- deploy using release-it
- Don't hide series names on hover
##### v0.0.8
- Support Snapshots (thanks @londonanthonyoleary)
- Direct link rendered image now works.
- Support UTC date display
- Fix display issue with 5.1
- Merge distinct values in legend unless showing the name
- Basic Annotation Support
- Fix mapping numeric data to text
##### v0.0.7
- Switch to typescript
- Override applyPanelTimeOverrides rather than issueQueries to extend time
- Support numeric unit conversion
- New rendering pipeline (thanks @jonyrock)
- Don't detect duplicate colors from metrics
- Formatting with prettier.js
- Only hide hover text when it collides
- Show time axis (copied from novatec-grafana-discrete-panel)
- Improved text collision behavior
##### v0.0.6
- Fix for grafana 4.5 (thanks @alin-amana)
##### v0.0.5
- Support results from the table format
- Support results in ascending or decending order
- Configure legend percentage decimal points
- Legend can show transition count and distinct value count
- Clamp percentage stats within the query time window
- Changed the grafana dependency version to 4.x.x, since 3.x.x was not really supported
- Fixed issues with tooltip hover position
- Option to expand 'from' query so the inital state can avoid 'null'
##### v0.0.4
- Support shared tooltips (not just crosshair)
##### v0.0.3
- Configure more colors (retzkek)
- Fix tooltips (retzkek)
- Configure Text Size
- Support shared crosshair
##### v0.0.2
- Use the panel time shift.
##### v0.0.1
- First working version
