title: "Histogram panel plugin for Grafana"
description: "Histogram Panel for Grafana. Histogram panel plugin for Grafana by mtanda. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/mtanda-histogram-panel/
# Histogram
- Developer: mtanda
- Version: 0.1.7
![Histogram](https://grafana.com/api/plugins/mtanda-histogram-panel/versions/0.1.7/images/images/histogram.png)
## Histogram Panel Plugin for Grafana
This plugin show the Histogram of time series data.
![](https://raw.githubusercontent.com/mtanda/grafana-histogram-panel/master/dist/images/histogram.png)
### How this plugin works
This plugin receives raw time series data, and count each value occurrence, and then show the occurrence as histogram.
### Supported Datasources
I confirmed this plugin work with following datasource.
- Prometheus
But, this plugin can handle time series data (defined by Grafana plugin interface).
Should work with Graphite / InfluxDB / OpenTSDB.
### Options
- Bucket Size
  - Can configure bucket size to make histogram data.
### Known Issues
- This plugin doesn't support Elasticsearch aggregation.
  - As noted above, this plugin make histogram data in plugin.
  - Can't handle the Elasticsearch aggregation result yet.
#### Changelog
##### v0.1.6
- Support Grafana 4.0
##### v0.1.5
- Refactoring
##### v0.1.4
- Add template variable support
- Add bucket mode
- Fix sorting of buckets
- Fix tooltip display
##### v0.1.3
- Fix avg legend
##### v0.1.2
- Add min/max option
##### v0.1.1
- Update document
