title: "Treemap panel plugin for Grafana"
description: "Area-based visualization of hierarchical data. Treemap panel plugin for Grafana by Grafana Labs. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/marcusolsson-treemap-panel/
# Treemap
- Developer: Grafana Labs
- Version: 2.1.1
- [Installation](https://grafana.com/grafana/plugins/marcusolsson-treemap-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/marcusolsson-treemap-panel/changelog.md)
![Treemap](https://grafana.com/api/plugins/marcusolsson-treemap-panel/versions/2.1.1/images/img/screenshot.png)
# Treemap for Grafana
[![CI](https://github.com/grafana/grafana-treemap-panel/actions/workflows/push.yml/badge.svg)](https://github.com/grafana/grafana-treemap-panel/actions/workflows/push.yml) [![CD](https://github.com/grafana/grafana-treemap-panel/actions/workflows/publish.yml/badge.svg)](https://github.com/grafana/grafana-treemap-panel/actions/workflows/publish.yml) [![License](https://img.shields.io/github/license/grafana/grafana-treemap-panel)](https://grafana.com/grafana/plugins/marcusolsson-treemap-panel/)
> **Maintenance**: Now the plugin is being maintained by Grafana Labs. Big thanks to [Marcus Olsson](https://twitter.com/marcusolsson) for the awesome work!
A panel plugin for [Grafana](https://grafana.com/) to visualize tree maps.
![Screenshot](https://github.com/grafana/grafana-treemap-panel/raw/main/src/img/screenshot.png)
## Configuration
This section lists the available configuration options for the Treemap panel.
### Panel options
#### Dimensions
The dimension options determines what fields to use for each dimension of the visualization.
| Option              | Description        |
| _Label by_          | Field to use for the text label. Defaults to the first textual field. All values must be unique. |
| _Size by_           | Field to use for size. Defaults to the first numeric field.                                      |
| _Color by_          | Field to use for color. Defaults to the first numeric field.                                     |
| _Group by_          | Field to group by.        |
| _Additional labels_ | Fields to use as labels in the tooltip.                                                          |
#### Display
| _Tiling algorithm_ | Determines where to make each split. |
### Field options
| _Separator_ | Set this value to a non-empty string to create a hierarchy as defined by the path defined by the separator. |
