Business Input for Grafana
This project was originally contributed by Volkov Labs - thanks for all your great work!
[!CAUTION] This data source plugin is now in maintenance mode. It will continue to receive only minimal updates required for compatibility with Grafana 12.x. No new features will be developed. To ensure long-term support and access to new capabilities, we recommend using the Infinity data source plugin.
Legacy information
Business Input is a powerful Grafana plugin that enables you to store, emulate, and visualize static data effortlessly. Perfect for testing, prototyping, or creating custom visualizations without relying on external data sources.
🚀 Features
- Static Visualizations: Create dashboards independent of specific data sources.
- Flexible Data Input: Manually enter values or use the JavaScript Values Editor for dynamic data.
- AI-Powered Data Generation: Generate data using OpenAI and LLM applications.
- Custom Query Responses: Build tailored responses for testing or developing panel plugins.
- Dashboard Storage: Store data and images directly within Grafana dashboards.
- Variable Support: Use variables in text fields for dynamic content.
- Intuitive Inputs: Leverage Number inputs, Date Time Pickers, and Text Areas for seamless data entry.
📋 Requirements
Ensure your Grafana version matches the plugin version for compatibility:
| Plugin Version | Compatible Grafana Versions |
| 5.X | Grafana 11, Grafana 12 |
| 4.X | Grafana 10.3, Grafana 11 |
| 3.X | Grafana 9.2, Grafana 10 |
| 2.X | Grafana 8.5, Grafana 9 |
| 1.X | Grafana 7.3 |
🛠️ Installation
Install the Business Input data source via the Grafana Plugins Catalog or using the Grafana CLI:
grafana cli plugins install marcusolsson-static-datasource
📚 Documentation
Explore detailed guides to maximize the potential of Business Input:
| Section | Description |
| Provisioning | Learn how to automatically provision the data source. |
| Variables | Understand how to use variables for dynamic data. |
| Panels | See how to integrate with Grafana panels. |
| Release Notes | Stay updated with the latest features and changes. |
📜 License
This project is licensed under the Apache License Version 2.0. See the LICENSE file for details.
- ...and more
Insights
- Adoption
Running on 7,531 active Grafana instances.
- Activity
Last updated 27 Apr 2026.
3 releases in the past year.
- Queries
96,379,956 total queries served across all Grafana Cloud instances.
- Version
- 6.1.1
- Dependencies
- Grafana >=11.6.0
- Developer
- Grafana Labs
- ...and more
