title: "Hourly heatmap panel plugin for Grafana"
description: "Heatmap for the hours of the day. Hourly heatmap panel plugin for Grafana by Marcus Olsson. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/marcusolsson-hourly-heatmap-panel/
# Hourly heatmap
- Developer: Marcus Olsson
- Version: 2.0.1
- [Installation](https://grafana.com/grafana/plugins/marcusolsson-hourly-heatmap-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/marcusolsson-hourly-heatmap-panel/changelog.md)
![Hourly heatmap (Dark)](https://grafana.com/api/plugins/marcusolsson-hourly-heatmap-panel/versions/2.0.1/images/img/dark.png)
![Hourly heatmap (Light)](https://grafana.com/api/plugins/marcusolsson-hourly-heatmap-panel/versions/2.0.1/images/img/light.png)
# Hourly Heatmap for Grafana
[![Build](https://github.com/marcusolsson/grafana-hourly-heatmap-panel/workflows/CI/badge.svg)](https://github.com/marcusolsson/grafana-hourly-heatmap-panel/actions?query=workflow%3A%22CI%22) [![Release](https://github.com/marcusolsson/grafana-hourly-heatmap-panel/workflows/Release/badge.svg)](https://github.com/marcusolsson/grafana-hourly-heatmap-panel/actions?query=workflow%3ARelease) [![Marketplace](https://img.shields.io/badge/dynamic/json?logo=grafana\&color=F47A20\&label=marketplace\&prefix=v\&query=%24.items%5B%3F%28%40.slug%20%3D%3D%20%22marcusolsson-hourly-heatmap-panel%22%29%5D.version\&url=https%3A%2F%2Fgrafana.com%2Fapi%2Fplugins)](https://grafana.com/grafana/plugins/marcusolsson-hourly-heatmap-panel) [![Downloads](https://img.shields.io/badge/dynamic/json?logo=grafana\&color=F47A20\&label=downloads\&query=%24.items%5B%3F%28%40.slug%20%3D%3D%20%22marcusolsson-hourly-heatmap-panel%22%29%5D.downloads\&url=https%3A%2F%2Fgrafana.com%2Fapi%2Fplugins)](https://grafana.com/grafana/plugins/marcusolsson-hourly-heatmap-panel) [![License](https://img.shields.io/github/license/marcusolsson/grafana-hourly-heatmap-panel)](https://grafana.com/grafana/plugins/marcusolsson-hourly-heatmap-panel/) [![Twitter](https://img.shields.io/twitter/follow/marcusolsson?color=%231DA1F2\&label=twitter\&style=plastic)](https://twitter.com/marcusolsson) ![Maintenance](https://img.shields.io/maintenance/no/2022?style=plastic)
> **Important:** As of July 2022, I'm no longer actively maintaining this plugin. At the time of writing, I'm not aware of any replacement panel.
A panel plugin for [Grafana](https://grafana.com/) to visualize hourly heatmaps.
An hourly heatmap aggregates data into buckets by day and hour to analyze activity or traffic during the day.
![Screenshot](https://github.com/marcusolsson/grafana-hourly-heatmap-panel/raw/main/src/img/dark.png)
## Motivation
The [carpet-plot](https://github.com/petrslavotinek/grafana-carpetplot) panel plugin is one of the most used plugins for Grafana. Unfortunately, it's no longer being actively maintained.
Grafana 7.0 introduced a new plugin architecture based on React. Instead of migrating the original plugin from Angular, this is completely rewritten from scratch, using inspiration from the original plugin.
## Configuration
This section lists the available configuration options for the JSON API data source.
### Panel options
#### Dimensions
| Option  | Description                                                             |
| _Time_  | Name of the field to use for time. Defaults to the first time field.    |
| _Value_ | Name of the field to use for value. Defaults to the first number field. |
#### Display
| _Show cell border_ | Toggles a cell border to make it easier to distinguish cells with similar values        |
| _Show tooltip_     | Toggles the tooltip. Due to the current tooltip implementation, this severely impacts performance and I recommend that you disable this for large time intervals. For more information, refer to [#12](https://github.com/marcusolsson/grafana-hourly-heatmap-panel/issues/12). |
| _From_ and _To_    | Lets you choose the hours to display. This can be used to set working hours, or to filter parts of the day with low traffic        |
#### Legend
| _Show legend_          | Toggles the color spectrum        |
| _Show value indicator_ | Toggles an indicator that shows the current value in the legend        |
| _Gradient quality_     | Determines the quality of the color spectrum. Higher quality means more SVG elements being drawn. Reduce the quality if you experience degraded performance. |
### Field options
| _Group by_             | Size of each bucket        |
| _Calculation_          | Calculation to use for reducing data within a bucket        |
| _Color palette_        | Colors to use for the heatmap. Select from any of the predefined color palettes, or select **Custom** to create your own. Select **Field options** to use the colors from the built-in **Color scheme** field option |
| _Invert color palette_ | Inverts the currently selected color palette        |
| _Null value color_     | Color to display when a bucket contains no data as opposed to a data value of 0.        |
## Troubleshooting
### Missing data
By default, data sources limits the number of data points to the width of the panel in pixels. If you're visualizing data over a long time, then you may need to adjust the **Max data points** under **Query options** in the query editor.
![Missing data](https://github.com/marcusolsson/grafana-hourly-heatmap-panel/raw/main/src/img/missing-datapoints.png)
