title: "Business Calendar panel plugin for Grafana"
description: "Displays events in a sleek calendar view, pulling from diverse data sources for seamless integration. See install steps and the changelog."
> This is the Markdown version of https://grafana.com/grafana/plugins/marcusolsson-calendar-panel/
# Business Calendar
- Developer: Grafana Labs
- Version: 4.2.4
- [Installation](https://grafana.com/grafana/plugins/marcusolsson-calendar-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/marcusolsson-calendar-panel/changelog.md)
![Panel](https://grafana.com/api/plugins/marcusolsson-calendar-panel/versions/4.2.4/images/img/screenshot.png)
# Business Calendar for Grafana
[![CI](https://github.com/grafana/business-calendar/actions/workflows/push.yml/badge.svg)](https://github.com/grafana/business-calendar/actions/workflows/push.yml) [![CD](https://github.com/grafana/business-calendar/actions/workflows/publish.yml/badge.svg)](https://github.com/grafana/business-calendar/actions/workflows/publish.yml) [![License](https://img.shields.io/github/license/grafana/business-calendar)](https://github.com/grafana/business-calendar/blob/main/LICENSE)
> This project was originally contributed by [Volkov Labs](https://github.com/volkovlabs/business-calendar) — thanks for all your great work!
> We have republished under the same plugin ID, keeping the community signature. This means you can simply update your plugin version. A new ID would have required manual updates to your dashboards. For additional information on the changes, see the [Notices](https://github.com/grafana/business-calendar/blob/main/NOTICES.md).
This project is currently maintained by Grafana Labs. We welcome pull requests and will review them on a best-effort basis. If you're interested in taking on this project long-term, contact <integrations@grafana.com>. We're eager to work with new maintainers and eventually hand over the project.
**Business Calendar** is a powerful Grafana plugin that transforms your data into an intuitive calendar view. Seamlessly visualize schedules, deadlines, and time-based metrics from any Grafana-supported data source.
## 🚀 Features
- **Multi-Language Toolbar**: Switch between Day, Week, Month, Work Week, Year, and Agenda views with ease. Navigate to today’s events or browse time ranges.
- **Data Flexibility**: Integrate and display events from any Grafana data source.
- **Time Range Filtering**: Zoom in on specific periods for focused analysis.
- **Threshold Coloring**: Highlight events with customizable colors using Grafana thresholds.
- **Quick Links**: Click events to access data links directly (bypassing sidebars).
- **Annotations**: Display dashboard annotations for selected time ranges.
- **Localization**: Available in Spanish, French, German, Portuguese, and Chinese.
## 📋 Requirements
- **Version 4.x**: Grafana 11 or Grafana 12.
- **Version 3.x**: Grafana 10 or Grafana 11.
- **Version 2.x**: Grafana 9.2 or Grafana 10.
- **Version 1.x**: Grafana 8.5 or Grafana 9.
## 🛠️ Installation
Get started with Business Calendar in just a few steps:
1. Install the plugin via the [Grafana Plugins Catalog](https://grafana.com/grafana/plugins/marcusolsson-calendar-panel/) or using the Grafana CLI:
   ```bash
   grafana-cli plugins install marcusolsson-calendar-panel
2. Restart Grafana to load the plugin.
3. Add the **Business Calendar** panel to your dashboard and configure your data source.
## 📚 Documentation
Explore comprehensive guides and resources to master the plugin:
| Section        | Description                              |
| [Basic configuration](https://grafana.com/docs/plugins/marcusolsson-calendar-panel/latest/basic-config/)    | Learn the essentials to get started.     |
| [Configuration options](https://grafana.com/docs/plugins/marcusolsson-calendar-panel/latest/configuration/) | Dive into all customization settings.    |
| [Features](https://grafana.com/docs/plugins/marcusolsson-calendar-panel/latest/features/)                   | Discover key capabilities and use cases. |
| [Release notes](https://grafana.com/grafana/plugins/marcusolsson-calendar-panel/?tab=changelog)             | Stay updated on new features and fixes.  |
## 📜 License
This project is licensed under the [Apache License 2.0](https://github.com/grafana/business-calendar/blob/main/LICENSE).
