title: "Word cloud panel plugin for Grafana"
description: "WordCloud / TagCloud Panel. Word cloud panel plugin for Grafana by magnesium. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/magnesium-wordcloud-panel/
# Word cloud
- Developer: magnesium
- Version: 1.2.11
- [Installation](https://grafana.com/grafana/plugins/magnesium-wordcloud-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/magnesium-wordcloud-panel/changelog.md)
![panel](https://grafana.com/api/plugins/magnesium-wordcloud-panel/versions/1.2.11/images/img/wordcloud-screenshot.png)
![query](https://grafana.com/api/plugins/magnesium-wordcloud-panel/versions/1.2.11/images/img/wordcloud-screenshot-query.png)
[![Marketplace](https://img.shields.io/badge/dynamic/json?logo=grafana\&color=F47A20\&label=marketplace\&prefix=v\&query=%24.items%5B%3F%28%40.slug%20%3D%3D%20%22magnesium-wordcloud-panel%22%29%5D.version\&url=https%3A%2F%2Fgrafana.com%2Fapi%2Fplugins)](https://grafana.com/grafana/plugins/magnesium-wordcloud-panel) [![Downloads](https://img.shields.io/badge/dynamic/json?logo=grafana\&color=F47A20\&label=downloads\&query=%24.items%5B%3F%28%40.slug%20%3D%3D%20%22magnesium-wordcloud-panel%22%29%5D.downloads\&url=https%3A%2F%2Fgrafana.com%2Fapi%2Fplugins)](https://grafana.com/grafana/plugins/magnesium-wordcloud-panel)
# ☁️ WordCloud Panel Plugin
## ⚠️ Unmaintained and looking for a new owner ⚠️
I no longer have the time to maintain this plugin and would love for someone to take it over and continue development.
If you are interested, please comment in this [issue](https://github.com/raulsperoni/magnesium-wordcloud-panel/issues/24) 🙏
This is a Wordcloud/Tagcloud panel for Grafana 7.0+, using the amazing library [react-wordcloud](https://github.com/chrisrzhou/react-wordcloud)
This was boostraped using the new @grafana/toolkit
![Screenshot with query](https://raw.githubusercontent.com/raulsperoni/magnesium-wordcloud-panel/master/src/img/wordcloud-screenshot-query.png)
## Features
You can find features and personalization options [here](https://react-wordcloud.netlify.com/)
## Usage
You need to configure a datasource so that the query returns a list of tokens and group the result by terms. You should change the names of word, and count fields in the options tab of the plugin according to your query, if you don't default fields with matching types present in your query will be used. The amount of words is configured in the datasource settings. In those settings is also important that you choose "Order by: Doc Count".
Every other settings for the wordcloud can be changed in the plugin options tab.
## ToDo
It would be really nice to use the library's available callbacks to filter grafana dashboard data when a word is clicked. I haven't found a neat way to do this yet. [Issue #5](https://github.com/raulsperoni/magnesium-wordcloud-panel/issues/5)
