title: "Kentik data source plugin for Grafana"
description: "Visualize and explore Kentik network observability data in Grafana. Kentik data source plugin for Grafana by Kentik. See install steps and the changelog."
> This is the Markdown version of https://grafana.com/grafana/plugins/kentik-connect-datasource/
# Kentik
- Developer: Kentik
- Version: 3.0.1
- [Installation](https://grafana.com/grafana/plugins/kentik-connect-datasource/installation.md)
- [Change log](https://grafana.com/grafana/plugins/kentik-connect-datasource/changelog.md)
![Query Editor](https://grafana.com/api/plugins/kentik-connect-datasource/versions/3.0.1/images/img/queryeditor.png)
![Graph Panel](https://grafana.com/api/plugins/kentik-connect-datasource/versions/3.0.1/images/img/graphedit.png)
![Datasource Configuration](https://grafana.com/api/plugins/kentik-connect-datasource/versions/3.0.1/images/img/datasourceconfig.png)
# Kentik for Grafana
The Kentik datasource plugin allows you to query the Kentik API and visualize network traffic data directly in Grafana. It leverages the **Kentik Network Observability Platform** to provide real-time, Internet-scale ingest and querying of network data including flow records (NetFlow, IPFIX, sFlow), BGP, GeoIP, and SNMP.
The plugin provides instant access to the **Kentik Data Engine (KDE)**, enabling you to seamlessly integrate network activity metrics into your Grafana dashboards.
## Requirements
- A Grafana instance (v10.4 or later)
- An active **Kentik account** with API access
- Devices registered in the Kentik portal
## Getting Started
1. Navigate to **Data Sources** in Grafana.
2. Add **Kentik**.
3. Select the appropriate **Region** (US, EU, or Custom).
4. Enter your Kentik **Email** and **API Token**.
5. Click **Save & Test** to verify connectivity.
## Features
- **Granular Visibility**: View traffic by time range, devices, sites, and over 200 dimensions across 20+ categories.
- **Multi-Select Support**: Select multiple sites, devices, and up to 8 dimensions simultaneously.
- **NMS / SNMP Support**: Query SNMP device and interface metrics alongside traditional flow data.
- **Smart Labeling**: Customize graph legends using Alias and Prefix fields with autocomplete (e.g., `{{Source Interface}}`, `$col`, `$metric_group`).
- **Drilldown Workflows**: Deep-link URLs to the Kentik Portal for detailed investigation.
## Documentation
For more information, visit [Kentik Documentation](https://kb.kentik.com/).
