title: "SPC Pareto panel plugin for Grafana"
description: "Pareto chart with cumulative percentage line, threshold highlighting, and statistics table. SPC Pareto panel plugin for Grafana by Kenso Software."
> This is the Markdown version of https://grafana.com/grafana/plugins/kensobi-spcpareto-panel/
# SPC Pareto
- Developer: Kenso Software
- Version: 1.1.0
- [Installation](https://grafana.com/grafana/plugins/kensobi-spcpareto-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/kensobi-spcpareto-panel/changelog.md)
![Vital Few](https://grafana.com/api/plugins/kensobi-spcpareto-panel/versions/1.1.0/images/img/vital-few.png)
![Group](https://grafana.com/api/plugins/kensobi-spcpareto-panel/versions/1.1.0/images/img/group-chart.png)
![Editor](https://grafana.com/api/plugins/kensobi-spcpareto-panel/versions/1.1.0/images/img/editor.png)
![No Table](https://grafana.com/api/plugins/kensobi-spcpareto-panel/versions/1.1.0/images/img/no-table.png)
![All options enabled](https://grafana.com/api/plugins/kensobi-spcpareto-panel/versions/1.1.0/images/img/all-enabled.png)
![Labels and Percentages](https://grafana.com/api/plugins/kensobi-spcpareto-panel/versions/1.1.0/images/img/labels-perc.png)
![Dynamic JSON Badge](https://img.shields.io/badge/dynamic/json?logo=grafana\&query=$.version\&url=https://grafana.com/api/plugins/kensobi-spcpareto-panel\&label=Marketplace\&prefix=v\&color=F47A20) ![Grafana](https://img.shields.io/badge/Grafana-11%2B-orange?logo=grafana)
The SPC Pareto panel helps you identify the most significant factors contributing to defects, downtime, or any categorical issue — so you can focus improvement efforts where they matter most.
![SPC Pareto panel overview](https://raw.githubusercontent.com/kensobi/spc-pareto/main/src/img/group-chart.png)
## Why SPC Pareto?
The **Pareto principle** (80/20 rule) states that roughly 80% of effects come from 20% of causes. This plugin makes that insight instantly visible:
- **Bars sorted by impact** — categories are automatically ranked from highest to lowest frequency, making the biggest contributors immediately obvious
- **Cumulative percentage line** — a running total overlay shows how quickly contributions accumulate toward 100%
- **80/20 threshold line** — a configurable threshold line highlights where the "vital few" end and the "trivial many" begin
![Pareto chart with threshold](https://raw.githubusercontent.com/kensobi/spc-pareto/main/src/img/vital-few.png)
## Built for Grafana
SPC Pareto is built using Grafana's native visualization components. This means it inherits the look, feel, and behavior you already know:
- **Native theming** — automatically adapts to light and dark mode
- **Standard panel options** — legend placement, tooltip behavior, and field overrides work just like any other Grafana panel
- **Resizable statistics table** — drag the splitter to balance chart and table space, just like Grafana's built-in panels
- **Works with any data source** — use it with SQL databases, Prometheus, InfluxDB, CSV files, or any other Grafana data source
## Features
| Feature                | Description        |
| Raw data support       | Accepts ungrouped observations and counts occurrences automatically                                            |
| Automatic sorting      | Categories are ranked by frequency — no manual ordering needed                                                 |
| Dual y-axes            | Left axis shows frequency counts, right axis shows cumulative percentage (0–100%)                              |
| Threshold line         | Configurable threshold (default 80%) with horizontal and vertical reference lines                              |
| Vital few highlight    | Bars beyond the threshold crossing point are visually muted, making the vital few stand out                    |
| Cumulative line        | Customizable color, width, and point markers        |
| Top N / Other grouping | Collapse low-frequency categories into an "Other" bucket to reduce noise                                       |
| Value labels           | Optional count, percentage, or both displayed above each bar                                                   |
| Statistics table       | Table with category, frequency, % of total, cumulative count, and cumulative % — always in Pareto order        |
| Standard options       | Unit, decimals, and display name apply to frequency values across the axis, labels, tooltip, legend, and table |
| Resizable layout       | Drag the splitter between chart and table to adjust the view                                                   |
![Statistics table](https://raw.githubusercontent.com/kensobi/spc-pareto/main/src/img/all-enabled.png)
## Use Cases
- **Manufacturing quality** — identify top defect types across production lines
- **IT operations** — rank incident categories to prioritize root cause analysis
- **Customer support** — surface the most common complaint categories
- **Software development** — analyze bug categories, test failure reasons, or build errors
- **Supply chain** — rank supplier issues or shipment delay causes
## Requirements
- Grafana **11** or later
## Getting Started
1. Install the plugin from the [Grafana Plugin Catalog](https://grafana.com/grafana/plugins/kensobi-spcpareto-panel/)
2. Add a new panel and select **SPC Pareto** as the visualization
3. Configure a query that returns either:
   - A **string field** + a **number field** (pre-aggregated categories and counts), or
   - A **string field** only (raw observations — the plugin counts occurrences automatically)
4. The chart automatically sorts, calculates cumulative percentages, and renders the Pareto view
![Panel configuration](https://raw.githubusercontent.com/kensobi/spc-pareto/main/src/img/editor.png)
### Example Query (SQL — pre-aggregated)
```sql
SELECT defect_type AS category, COUNT(*) AS count
FROM inspections
WHERE $__timeFilter(inspection_time)
GROUP BY defect_type
### Example Query (SQL — raw observations)
```sql
SELECT defect_type
FROM inspections
The plugin counts occurrences of each unique `defect_type` value automatically.
### Data handling rules
- The **first string field** in each query result is used as the category, and the **first number field** (if present) as the value. If a query returns multiple number fields, reorder or remove columns so the intended value comes first.
- Query results with both a string and a number field are treated as pre-aggregated; results with only a string field are counted as raw observations. Multiple queries can be combined.
- Rows with a **missing category or missing value** (null, NaN) are excluded from the analysis. When rows are excluded, a note appears below the statistics table.
- **Negative values are not valid** for Pareto analysis. If the data contains a negative value, the panel shows an error instead of a misleading chart.
### Example Query (TestData)
For a quick demo, use the **TestData** data source with the **CSV Content** scenario:
```csv
category,count
Scratch,45
Dent,38
Contamination,29
Misalignment,22
Color Defect,15
Crack,12
Burr,8
Warping,6
Porosity,4
## Panel Options
### Threshold
| Option              | Description                                            | Default |
| Show threshold line | Display the 80/20 reference lines                      | On      |
| Threshold value     | Cumulative percentage threshold                        | 80%     |
| Highlight vital few | Visually mute bars beyond the threshold crossing point | Off     |
| Trivial bar opacity | Opacity for the muted "trivial many" bars (10–100%)    | 40%     |
### Cumulative line
| Line color  | Color of the cumulative percentage line   | Orange  |
| Line width  | Stroke width of the cumulative line       | 2       |
| Show points | Show point markers on the cumulative line | On      |
| Point size  | Size of point markers                     | 5       |
### Top N / Other
| Limit categories      | Group low-frequency categories into an "Other" bucket | Off     |
| Show top N categories | Number of categories to show before grouping the rest | 10      |
### Bar
| Bar color         | Color of the frequency bars   | Blue    |
| Fill opacity      | Bar fill opacity (0–100%)     | 80%     |
| Line width        | Bar border width              | 1       |
| Gradient mode     | None, Opacity, or Hue         | None    |
| Show value labels | Display labels above each bar | Off     |
| Label content     | Count, % of Total, or Both    | Count   |
### Statistics table
| Show statistics table | Display the statistics table below the chart | On      |
### Standard options
| Unit         | Unit applied to frequency values (y-axis, bar labels, tooltip, table)        |
| Decimals     | Number of decimal places for frequency values; when set explicitly, it also applies to the computed percentage columns (default: 1 decimal) |
| Display name | Renames the value series in the legend, tooltip, and table column header (default "Frequency")                                              |
## Documentation
For detailed documentation, configuration guides, and examples, see the [full documentation](https://docs.kensobi.com/panels/spc-pareto/).
## Part of the KensoBI SPC Suite
SPC Pareto is part of a growing family of **Statistical Process Control** plugins for Grafana by Kenso Software:
**[SPC Chart Panel](https://github.com/KensoBI/spc-cad)** — Control charts for monitoring process stability over time. Supports Xbar-R, Xbar-S, and XmR charts with automatic calculation of control limits. If you're tracking whether a process is staying in control, this is your starting point.
**[SPC Histogram Panel](https://github.com/KensoBI/spc-histogram)** — Distribution analysis with histograms, bell curves, and a built-in statistics table showing Cp, Cpk, Pp, and Ppk. Use it to understand process capability: is your process producing results within specification limits?
**[SPC CAD Panel](https://github.com/KensoBI/spc-cad)** — Brings 3D geometry into the picture, letting you bind the data from control charts and histograms to physical features on your parts.
## License
This software is distributed under the AGPL-3.0-only license — see [LICENSE](https://raw.githubusercontent.com/KensoBI/spc-pareto/refs/heads/main/LICENSE) for details.
## Support
If you have any questions or feedback, you can:
- Ask a question on the [KensoBI Discord channel](https://discord.gg/bekfAuAjGm).
- GitHub Issues: <https://github.com/kensobi/spc-pareto/issues>
