title: "SPC Histogram panel plugin for Grafana"
description: "Histogram panel with SPC control limits, bell curves, and capability indices. SPC Histogram panel plugin for Grafana by Kenso Software."
> This is the Markdown version of https://grafana.com/grafana/plugins/kensobi-spchistogram-panel/
# SPC Histogram
- Developer: Kenso Software
- Version: 1.5.2
- [Installation](https://grafana.com/grafana/plugins/kensobi-spchistogram-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/kensobi-spchistogram-panel/changelog.md)
![SPC Histogram](https://grafana.com/api/plugins/kensobi-spchistogram-panel/versions/1.5.2/images/img/spc-histogram-release.gif)
![Stat table](https://grafana.com/api/plugins/kensobi-spchistogram-panel/versions/1.5.2/images/img/stat-table.png)
![Multi-series](https://grafana.com/api/plugins/kensobi-spchistogram-panel/versions/1.5.2/images/img/multi-series.png)
![Gaussian](https://grafana.com/api/plugins/kensobi-spchistogram-panel/versions/1.5.2/images/img/gaussian-curve.png)
![Editor](https://grafana.com/api/plugins/kensobi-spchistogram-panel/versions/1.5.2/images/img/histogram-feature.gif)
![Dynamic JSON Badge](https://img.shields.io/badge/dynamic/json?logo=grafana\&query=$.version\&url=https://grafana.com/api/plugins/kensobi-spchistogram-panel\&label=Marketplace\&prefix=v\&color=F47A20) ![Grafana](https://img.shields.io/badge/Grafana-11.6.2%2B-orange?logo=grafana)
Visualize your process data distributions with built-in **Statistical Process Control** — right inside Grafana. SPC Histogram turns your time series data into interactive histograms with automatic control limits, bell curves, capability indices, and a detailed statistics table.
![SPC Histogram](https://raw.githubusercontent.com/KensoBI/spc-histogram/main/src/img/spc-histogram-release.gif)
## Why SPC Histogram?
Histograms are a fundamental tool for understanding process data. When combined with Statistical Process Control, they answer the key questions about your process:
- **Control limits** — automatically calculated LCL/UCL lines show whether variation is within expected bounds
- **Capability indices** — Cp, Cpk, Pp, and Ppk tell you whether your process fits within specification limits
- **Bell curves** — Gaussian curves fitted using the Levenberg-Marquardt algorithm reveal how closely your data follows a normal distribution
- **Statistics at a glance** — a built-in table displays n, Mean, Std Dev, Min, Max, and more for every series
![Gaussian Curve](https://raw.githubusercontent.com/KensoBI/spc-histogram/main/src/img/gaussian-curve.png)
## Built for Grafana
SPC Histogram is built using Grafana's native visualization components. This means it inherits the look, feel, and behavior you already know:
- **Native theming** — automatically adapts to light and dark mode
- **Standard panel options** — legend placement, tooltip behavior, and field overrides work just like any other Grafana panel
- **Resizable statistics table** — drag the splitter to balance chart and table space, just like Grafana's built-in panels
- **Works with any data source** — use it with SQL databases, Prometheus, InfluxDB, CSV files, or any other Grafana data source
## Features
| Feature              | Description                                                            |
| Control charts       | XmR, Xbar-R, and Xbar-S chart types with automatic LCL/UCL calculation |
| Bell curves          | Gaussian (Levenberg-Marquardt fit) and histogram curve overlays        |
| Statistics table     | n, Mean, Std Dev, Min, Max, LCL, UCL, Cp, Cpk, Pp, Ppk per series      |
| Custom control lines | Static values or dynamic values pulled from a separate query           |
| Specification limits | LSL/USL with automatic capability index calculation                    |
| Multiple series      | Compare distributions side by side or combine into one histogram       |
| Aggregation          | Mean, Range, Standard Deviation, and Moving Range modes                |
| Export to CSV        | Export statistics, control lines, and histogram buckets to CSV         |
| Interactive tooltips | Bucket counts, control line values, and Gaussian curve values on hover |
| Resizable layout     | Drag the splitter between chart and statistics table                   |
![Statistics Table](https://raw.githubusercontent.com/KensoBI/spc-histogram/main/src/img/stat-table.png)
## Use Cases
- **Manufacturing quality** — monitor dimensional tolerances with control limits and capability indices
- **Process engineering** — track measurement stability and detect shifts in process centering
- **Laboratory testing** — analyze instrument measurement distributions and repeatability
- **Supply chain** — monitor incoming material quality against specification limits
- **Pharmaceutical** — validate process capability for batch manufacturing (Cp/Cpk)
## Requirements
- Grafana **11** or later
## Getting Started
1. Install the plugin from the [Grafana Plugin Catalog](https://grafana.com/grafana/plugins/kensobi-spchistogram-panel/)
2. Add a new panel and select **SPC Histogram** as the visualization
3. Connect a data source with time series data
4. Choose a **Chart Type** (XmR, Xbar-R, or Xbar-S) to enable automatic control limits
5. Add **Control Lines** for specification limits (LSL/USL) to see capability indices
6. Add a **Bell Curve** to visualize the distribution fit
![Multiple Series](https://raw.githubusercontent.com/KensoBI/spc-histogram/main/src/img/multi-series.png)
## Panel Options
### Histogram
| Option          | Description                                          | Default |
| Bucket count    | Approximate number of histogram bars                 | 30      |
| Bucket size     | Fixed width for each bucket (overrides bucket count) | Auto    |
| Bucket offset   | Shifts bucket boundaries by a fixed amount           | 0       |
| Combine series  | Merge all series into a single histogram             | Off     |
| Feature Queries | Select queries excluded from histogram calculations  | None    |
### SPC
| Chart type       | none, X chart (XmR), mR chart (XmR), X chart (Xbar-R), R chart (Xbar-R), X chart (Xbar-S), S chart (Xbar-S) | none    |
| Subgroup size    | Number of measurements per subgroup        | 1       |
| Aggregation type | None, Moving range, Mean, Range, Standard Deviation. Only available when chart type is "none".              | None    |
| Control lines    | LCL, UCL, Mean, Min, Max, Range, LSL, USL, Gaussian Peak, Custom, Nominal                                   | None    |
### Curve
| Add a Bell Curve | Gaussian or Histogram curve with configurable series, line width, and color | None    |
### Statistics Table
| Show statistics table | Display the statistics table below the histogram       | Off     |
| Visible columns       | n, Mean, Std Dev, Min, Max, LCL, UCL, Cp, Cpk, Pp, Ppk | All     |
### Bar Appearance
| Fill opacity  | Bar fill opacity (0–100%) | 80%     |
| Line width    | Bar border width (0–10)   | 1       |
| Gradient mode | None, Opacity, or Hue     | None    |
## Documentation
For detailed documentation, configuration guides, and examples, see the [full documentation](https://docs.kensobi.com/panels/spc-histogram/).
## Part of the KensoBI SPC Suite
SPC Histogram is part of a growing family of **Statistical Process Control** plugins for Grafana by Kenso Software:
**[SPC Chart Panel](https://grafana.com/grafana/plugins/kensobi-spc-panel/)** — Control charts for monitoring process stability over time. Supports Xbar-R, Xbar-S, and XmR charts with automatic calculation of control limits. If you're tracking whether a process is staying in control, this is your starting point.
**[SPC Pareto Panel](https://grafana.com/grafana/plugins/kensobi-spcpareto-panel/)** — Pareto charts for identifying the most significant factors contributing to defects or issues. Automatic sorting, cumulative percentage lines, and 80/20 threshold analysis help you focus improvement efforts where they matter most.
**[SPC CAD Panel](https://grafana.com/grafana/plugins/kensobi-spccad-panel/)** — Brings 3D geometry into the picture, letting you bind the data from control charts and histograms to physical features on your parts.
## License
This software is distributed under the AGPL-3.0-only license — see [LICENSE](https://raw.githubusercontent.com/KensoBI/spc-histogram/refs/heads/main/LICENSE) for details.
## Support
If you have any questions or feedback, you can:
- Ask a question on the [KensoBI Discord channel](https://discord.gg/bekfAuAjGm).
- GitHub Issues: <https://github.com/KensoBI/spc-histogram/issues>
