title: "SPC CAD panel plugin for Grafana"
description: "Perform statistical analysis on 3D CAD model features. SPC CAD panel plugin for Grafana by Kenso Software. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/kensobi-spccad-panel/
# SPC CAD
- Developer: Kenso Software
- Version: 3.1.1
- [Installation](https://grafana.com/grafana/plugins/kensobi-spccad-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/kensobi-spccad-panel/changelog.md)
![CAD demo](https://grafana.com/api/plugins/kensobi-spccad-panel/versions/3.1.1/images/img/pointcloud.png)
![CAD ](https://grafana.com/api/plugins/kensobi-spccad-panel/versions/3.1.1/images/img/cad-demo-small.gif)
![Forecasting](https://grafana.com/api/plugins/kensobi-spccad-panel/versions/3.1.1/images/img/forecasting.png)
![Color mapping](https://grafana.com/api/plugins/kensobi-spccad-panel/versions/3.1.1/images/img/color-mapping.png)
![Annotations](https://grafana.com/api/plugins/kensobi-spccad-panel/versions/3.1.1/images/img/annotations.png)
![Cube features](https://grafana.com/api/plugins/kensobi-spccad-panel/versions/3.1.1/images/img/cube-features.png)
![Custom feature templates](https://grafana.com/api/plugins/kensobi-spccad-panel/versions/3.1.1/images/img/custom-templates.png)
# SPC CAD Panel
Bring your 3D models to life inside Grafana. Visualize CAD geometry, overlay real measurement data, and spot quality issues at a glance — all from your dashboard.
![SPC CAD Panel](https://raw.githubusercontent.com/KensoBI/spc-cad/refs/heads/main/src/img/pointcloud.png)
## Why SPC CAD?
Manufacturing quality teams spend hours switching between measurement software, spreadsheets, and reporting tools. SPC CAD Panel puts everything in one place: your 3D model, your data, and your analysis — live, interactive, and shareable across your organization.
## Key Features
### Interactive 3D Visualization
Load STL, 3MF, PLY, and ASC files directly into your dashboard. Rotate, pan, and zoom with intuitive trackball controls. Display multiple models side by side for assembly-level inspection.
### Feature Annotations
Click any measurement feature on your model to see its data. Annotations combine tables, time-series charts, and custom grid layouts — all populated from your Grafana queries in real time.
![Feature Annotations](https://raw.githubusercontent.com/KensoBI/spc-cad/refs/heads/main/src/img/annotations.png)
### Forecasting
See where your process is heading. When paired with the [KensoBI SPC Characteristic Datasource](https://grafana.com/grafana/plugins/kensobi-spccharacteristic-datasource/), the panel displays forecast trends with upper and lower confidence bands directly on feature charts — helping you act before problems occur.
![Forecasting](https://raw.githubusercontent.com/KensoBI/spc-cad/refs/heads/main/src/img/forecasting.png)
### Point Cloud Deviation Analysis
Overlay scan data on your CAD model with automatic deviation color mapping. A blue-to-red gradient instantly highlights where your part deviates from nominal.
### Color-Coded Quality Status
Define rules to color features based on measurement values — green for in-spec, red for out-of-tolerance, or any scheme that fits your workflow. Spot problems without reading a single number.
![Color Mapping](https://raw.githubusercontent.com/KensoBI/spc-cad/refs/heads/main/src/img/color-mapping.png)
### 13 Built-in Templates
Pre-configured annotation layouts for common feature types: point, circle, cylinder, sphere, ellipse, line, rectangle, slot, plane, slab, cone, and more. Select a template and your annotation is ready — or customize it to fit your needs.
![Custom Templates](https://raw.githubusercontent.com/KensoBI/spc-cad/refs/heads/main/src/img/custom-templates.png)
### Scan Timeline
Navigate through historical scan data with a built-in timeline slider. Play back inspections over time to track process trends and catch drift early.
## Getting Started
1. Install the plugin in your Grafana instance
2. Create a new panel and select **SPC CAD** as the visualization
3. Add a CAD model URL or upload a file (STL, 3MF, PLY, or ASC)
4. Connect a data query with your feature measurements
5. Click features on the model to create annotations
## Supported Formats
| Format | Extension | Description                           |
| STL    | `.stl`    | Stereolithography (binary and ASCII)  |
| 3MF    | `.3mf`    | 3D Manufacturing Format               |
| PLY    | `.ply`    | Polygon File Format                   |
| ASC    | `.asc`    | ASCII Point Cloud with deviation data |
All formats support GZIP compression for faster loading.
## Documentation
For detailed setup guides, data model requirements, configuration options, and troubleshooting, visit the [full documentation](https://docs.kensobi.com/panels/cad/).
## Getting Help
- [Documentation](https://docs.kensobi.com/panels/cad/) — Setup guides and reference
- [Discord Community](https://discord.gg/cVKKh7trXU) — Ask questions and share dashboards
- [GitHub Issues](https://github.com/KensoBI/spc-cad/issues) — Report bugs and request features
## License
This software is distributed under the [GNU Affero General Public License v3.0](https://raw.githubusercontent.com/KensoBI/spc-cad/refs/heads/main/LICENSE).
## Copyright
Copyright (c) 2026 [Kenso Software](https://kensobi.com/)
