title: "SPC Bullet panel plugin for Grafana"
description: "Bullet chart, progress bar, and bar gauge with optional SPC mode. SPC Bullet panel plugin for Grafana by Kenso Software."
> This is the Markdown version of https://grafana.com/grafana/plugins/kensobi-spcbullet-panel/
# SPC Bullet
- Developer: Kenso Software
- Version: 1.0.2
- [Change log](https://grafana.com/grafana/plugins/kensobi-spcbullet-panel/changelog.md)
![Main](https://grafana.com/api/plugins/kensobi-spcbullet-panel/versions/1.0.2/images/img/main.png)
![Main White](https://grafana.com/api/plugins/kensobi-spcbullet-panel/versions/1.0.2/images/img/main-white.png)
![Bullet Vertical](https://grafana.com/api/plugins/kensobi-spcbullet-panel/versions/1.0.2/images/img/bullet-vertical.png)
![Simple Progress](https://grafana.com/api/plugins/kensobi-spcbullet-panel/versions/1.0.2/images/img/simple-progress.png)
![Repeater](https://grafana.com/api/plugins/kensobi-spcbullet-panel/versions/1.0.2/images/img/repeater.png)
![SPC](https://grafana.com/api/plugins/kensobi-spcbullet-panel/versions/1.0.2/images/img/spc.png)
![SPC Editor](https://grafana.com/api/plugins/kensobi-spcbullet-panel/versions/1.0.2/images/img/spc-editor.png)
![Dynamic JSON Badge](https://img.shields.io/badge/dynamic/json?logo=grafana\&query=$.version\&url=https://grafana.com/api/plugins/kensobi-spcbullet-panel\&label=Marketplace\&prefix=v\&color=F47A20) ![Grafana](https://img.shields.io/badge/Grafana-12.3.2%2B-orange?logo=grafana)
A versatile bar visualization panel that works as a **progress bar**, **bar gauge**, or full **bullet chart** with qualitative background zones — with optional **SPC (Statistical Process Control)** mode to display process capability indices like Cpk, Ppk, and Sigma Level, computed directly from your time series data.
![SPC Bullet](https://docs.kensobi.com/assets/images/main-e8f31f1ebe94f5f7acde751b4eeee347.png)
## Why SPC Bullet?
Bullet charts communicate more information than a single gauge. In one compact bar you see the current value, the target, and the qualitative performance context — all without building separate panels or complex transformations.
- **Progress bar** — clean fill bar for completion percentages, utilization, or any 0–100% metric
- **Bullet chart** — qualitative background zones from Grafana thresholds show whether performance is acceptable at a glance
- **Target marker** — compare actual vs. goal with a secondary marker from any data field
- **SPC metrics (optional)** — display Mean, Std Dev, Cpk, Cp, Ppk, Pp, or Sigma Level computed from the full time series
## Built for Grafana
- **Native theming** — automatically adapts to light and dark mode
- **Standard field options** — min, max, units, decimals, and field overrides work just like any other Grafana panel
- **Threshold integration** — fill color and background zones are driven by Grafana's built-in threshold editor
- **Works with any data source** — SQL databases, Prometheus, InfluxDB, CSV files, or any other Grafana data source
## Features
| Feature                | Description        |
| Progress bar mode      | Simple filled bar with threshold-based color                                  |
| Bullet chart mode      | Filled bar with semi-transparent qualitative background zones from thresholds |
| Target marker          | Secondary marker from a data field — 6 configurable shapes                    |
| Horizontal & vertical  | Full support for both orientations                                            |
| Value label            | Numeric value displayed inside or outside the bar with configurable font size |
| Axis                   | Optional scale axis with smart tick formatting                                |
| SPC metrics (optional) | Mean, Std Dev, Cpk, Cp, Ppk, Pp, Sigma Level — computed from the full series  |
| Specification limits   | LSL and USL for capability and sigma level calculations                       |
| Multi-series support   | One bullet per data series, stacked automatically                             |
![SPC Bullet](https://docs.kensobi.com/assets/images/bullet-vertical-d1d4b566913ce7dac0fd2fb0bb847ddb.png)
## Use Cases
- **Manufacturing KPIs** — display Cpk or Ppk for each process parameter on a single dashboard page
- **OEE dashboards** — show availability, performance, and quality as bullet bars against targets
- **Production progress** — track shift output vs. daily target with a compact progress bar
- **Quality scorecards** — summarize process health across many parameters in a grid of bullets
- **IT operations** — monitor SLA compliance with clear red/yellow/green performance zones
- **Laboratory** — display capability indices against specification limits for each measured characteristic
## Requirements
- Grafana **11.6.2** or later
## Getting Started
1. Install the plugin from the [Grafana Plugin Catalog](https://grafana.com/grafana/plugins/kensobi-spcbullet-panel/)
2. Add a new panel and select **Bullet** as the visualization
3. Connect a data source with numeric data
4. Set **Min** and **Max** in field configuration to define the bar scale
5. Add **Thresholds** for color zones and bullet background ranges
6. Optionally select a **Target marker** field and configure its shape
7. Optionally enable **SPC > Metric** (e.g., Cpk) to display a process capability metric
## Panel Options
![SPC Bullet](https://docs.kensobi.com/assets/images/spc-editor-77ebb08a420c3122b57ebaed41bc7c14.png)
### Bullet
| Option         | Description                                        | Default    |
| Bullet mode    | `Progress bar` or `Bullet` (with background zones) | Bullet     |
| Orientation    | `Horizontal` or `Vertical`                         | Horizontal |
| Bar thickness  | Bar width as % of available space                  | 50%        |
| Fill thickness | Fill bar height as % of bar thickness              | 100%       |
### Value Label
| Show      | Display the numeric value on the bar                 | On      |
| Placement | `Inside` (right-aligned) or `Outside` (left-aligned) | Inside  |
| Font size | Text size in pixels (8–48px)                         | 14px    |
### Axis
| Show       | Display the scale axis with ticks | Off     |
| Tick count | Number of axis ticks (2–20)       | 5       |
### Target Marker
| Field name   | Data field used as the marker value                                    | _(none)_         |
| Marker shape | `Line`, `Circle`, `Diamond`, `Triangle`, `Inverted Triangle`, `Square` | Line             |
| Marker size  | Marker size in pixels (4–32px)                                         | 12px             |
| Marker color | Marker color                                                           | semi-dark-orange |
### SPC (optional)
SPC mode is disabled by default. Set **Metric** to any value other than `None` to enable it.
| Metric | `None`, `Mean`, `Std Dev`, `Cpk`, `Cp`, `Ppk`, `Pp`, `Sigma Level` | None    |
| LSL    | Lower specification limit                                          | 0       |
| USL    | Upper specification limit                                          | 100     |
## Documentation
For detailed documentation, configuration guides, and examples, see the [full documentation](https://docs.kensobi.com/panels/spc-bullet/).
## Part of the KensoBI SPC Suite
SPC Bullet is part of a growing family of **Statistical Process Control** plugins for Grafana by Kenso Software:
**[SPC Chart Panel](https://grafana.com/grafana/plugins/kensobi-spc-panel/)** — Control charts for monitoring process stability over time. Supports XmR, Xbar-R, and Xbar-S charts with automatic calculation of control limits.
**[SPC Histogram Panel](https://grafana.com/grafana/plugins/kensobi-spchistogram-panel/)** — Distribution analysis with histograms, bell curves, and a built-in statistics table showing Cp, Cpk, Pp, and Ppk.
**[SPC Box Plot Panel](https://grafana.com/grafana/plugins/kensobi-spcboxplot-panel/)** — Box-and-whisker plots with built-in SPC. Automatically groups measurements into subgroups, computes quartiles and outliers, and overlays Xf-Rf control limits to detect shifts in both process location and spread.
**[SPC Pareto Panel](https://grafana.com/grafana/plugins/kensobi-spcpareto-panel/)** — Pareto charts for identifying the most significant factors contributing to defects or issues.
**[SPC CAD Panel](https://grafana.com/grafana/plugins/kensobi-spccad-panel/)** — Brings 3D geometry into the picture, letting you bind the data from control charts and histograms to physical features on your parts.
**[SPC Characteristic Datasource](https://grafana.com/grafana/plugins/kensobi-spccharacteristic-datasource/)** — The datasource that powers the SPC CAD panel. Connects to your measurement database (PostgreSQL or MSSQL), lets you select features and characteristics through a point-and-click interface, and returns SPC statistics, time series measurements, and forecast data - no SQL required.
## License
This software is distributed under the [Kenso Software Commercial License](https://cdn.kensobi.com/plugins/pilot/LICENSE). Use requires a valid commercial license. No open-source rights are granted.
## Support
If you have any questions or feedback, you can:
- Contact support at <https://kensobi.com/contact>
- Join the [KensoBI Discord](https://discord.gg/cVKKh7trXU) for questions and discussion.
