title: "SPC Box Plot panel plugin for Grafana"
description: "Box-and-whisker plots with Xf-Rf control limits, outlier detection, and Cp/Cpk capability analysis. SPC Box Plot panel plugin for Grafana by Kenso Software."
> This is the Markdown version of https://grafana.com/grafana/plugins/kensobi-spcboxplot-panel/
# SPC Box Plot
- Developer: Kenso Software
- Version: 1.0.0
- [Installation](https://grafana.com/grafana/plugins/kensobi-spcboxplot-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/kensobi-spcboxplot-panel/changelog.md)
![SPC Box Plot overview](https://grafana.com/api/plugins/kensobi-spcboxplot-panel/versions/1.0.0/images/img/spc-boxplot-overview.png)
![Control lines and fill regions](https://grafana.com/api/plugins/kensobi-spcboxplot-panel/versions/1.0.0/images/img/spc-boxplot-fill-regions.png)
![Control lines](https://grafana.com/api/plugins/kensobi-spcboxplot-panel/versions/1.0.0/images/img/spc-boxplot-control-lines.png)
![Time series mode](https://grafana.com/api/plugins/kensobi-spcboxplot-panel/versions/1.0.0/images/img/spc-boxplot-timeseries.png)
![Categorical mode](https://grafana.com/api/plugins/kensobi-spcboxplot-panel/versions/1.0.0/images/img/spc-boxplot-categorical.png)
![Box appearance options](https://grafana.com/api/plugins/kensobi-spcboxplot-panel/versions/1.0.0/images/img/spc-boxplot-box-options.png)
![Statistics table](https://grafana.com/api/plugins/kensobi-spcboxplot-panel/versions/1.0.0/images/img/spc-boxplot-stats-table.png)
![Xf-Rf measurements](https://grafana.com/api/plugins/kensobi-spcboxplot-panel/versions/1.0.0/images/img/xfrf-meas-no-date.png)
![Dynamic JSON Badge](https://img.shields.io/badge/dynamic/json?logo=grafana\&query=$.version\&url=https://grafana.com/api/plugins/kensobi-spcboxplot-panel\&label=Marketplace\&prefix=v\&color=F47A20) ![Grafana](https://img.shields.io/badge/Grafana-11.6.10%2B-orange?logo=grafana)
Visualize process data distributions as box plots with built-in **Statistical Process Control** — right inside Grafana. SPC Box Plot groups your measurements into subgroups, draws standard box-and-whisker plots, and overlays robust Xf-Rf control limits so you can detect shifts in process spread and location at a glance.
![SPC Box Plot](https://docs.kensobi.com/assets/images/spc-boxplot-overview-db00936b8799577073ae426c5efbb030.png)
## Why SPC Box Plot?
Control charts tell you _when_ your process changes. Box plots tell you _how_ the distribution changes — median, spread, quartiles, and outliers all in one view. Combine them and you get both.
- **Resistant control limits** — the Xf-Rf method (Peixoto 2003) uses the middle half of each subgroup, so a few outliers cannot skew your limits
- **Three input modes** — works with raw time series data, categorically grouped observations, or pre-computed box statistics from your database
- **Outlier visibility** — individual points beyond 1.5 × IQR are plotted separately so they never disappear into the box
- **Capability at a glance** — add LSL/USL lines and the statistics table automatically shows Cp, Cpk, Pp, and Ppk for every subgroup
![SPC Box Plot with control lines](https://docs.kensobi.com/assets/images/spc-boxplot-control-lines-f2c428caaeb63391d9682355914fd1ed.png)
## Features
| Feature               | Description                                                             |
| Box-and-whisker plots | Q1/Q3 box, median line, whiskers (1.5 × IQR), individual outlier points |
| Mean marker           | Optional marker at the subgroup mean                                    |
| Xf-Rf SPC             | Robust control limits using resistant estimators (Peixoto 1992/2003)    |
| Three data modes      | Auto-detects time series, categorical, or pre-computed input            |
| Control lines         | LCL, UCL, Mean, Min, Max, Range, LSL, USL, Custom, Nominal              |
| Fill regions          | Shade areas between control lines to highlight process zones            |
| Statistics table      | n, Mean, Std Dev, Min, Max, Q1, Median, Q3, IQR, Cp, Cpk, Pp, Ppk       |
| Resizable layout      | Drag the splitter between chart and statistics table                    |
| Dashboard variables   | `subgroupsize` variable to control all panels from one dropdown         |
## Getting Started
1. Install from the [Grafana Plugin Catalog](https://grafana.com/grafana/plugins/kensobi-spcboxplot-panel/).
2. Add a panel and select **SPC Box Plot**.
3. Connect any data source returning numeric time series data.
4. Enable **SPC** in the panel options and set your subgroup size (4–15).
5. Add **LCL** and **UCL** control lines to see the process control zone.
6. Add **LSL** and **USL** lines to enable capability index calculations.
![Getting started](https://docs.kensobi.com/assets/images/spc-boxplot-getting-started-221893ccc614c659258802f05edaaa5d.gif)
## Documentation
For the complete feature reference — all panel options, data mode schemas, Xf-Rf formulas, capability index definitions, and dashboard variable configuration — see the **[full documentation](https://docs.kensobi.com/panels/spc-boxplot/)**.
## Part of the KensoBI SPC Suite
**[SPC Chart Panel](https://grafana.com/grafana/plugins/kensobi-spc-panel/)** — XmR, Xbar-R, and Xbar-S control charts for monitoring process stability over time.
**[SPC Histogram Panel](https://grafana.com/grafana/plugins/kensobi-spchistogram-panel/)** — Distribution analysis with histograms, bell curves, and capability indices.
**[SPC Pareto Panel](https://grafana.com/grafana/plugins/kensobi-spcpareto-panel/)** — Identify the most significant contributors to defects or downtime.
**[SPC CAD Panel](https://grafana.com/grafana/plugins/kensobi-spccad-panel/)** — Bind SPC data to 3D part geometry for visual quality inspection.
**[SPC Characteristic Datasource](https://grafana.com/grafana/plugins/kensobi-spccharacteristic-datasource/)** — The datasource that powers the SPC CAD panel. Connects to your measurement database (PostgreSQL or MSSQL), lets you select features and characteristics through a point-and-click interface, and returns SPC statistics, time series measurements, and forecast data - no SQL required.
## License
This software is distributed under the [Kenso Software Commercial License](https://cdn.kensobi.com/plugins/pilot/LICENSE). Use requires a valid commercial license. No open-source rights are granted.
## Getting Help
- Contact support at <https://kensobi.com/contact>
- [KensoBI Discord](https://discord.gg/cVKKh7trXU)
