title: "SPC Chart panel plugin for Grafana"
description: "Create common SPC charts like Xbar-R, XbarS, and XmR charts. SPC Chart panel plugin for Grafana by Kenso Software. See install steps and the changelog."
> This is the Markdown version of https://grafana.com/grafana/plugins/kensobi-spc-panel/
# SPC Chart
- Developer: Kenso Software
- Version: 2.4.0
- [Installation](https://grafana.com/grafana/plugins/kensobi-spc-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/kensobi-spc-panel/changelog.md)
![Numeric X with SPC table](https://grafana.com/api/plugins/kensobi-spc-panel/versions/2.4.0/images/img/numeric-x-table.png)
![Variable limits](https://grafana.com/api/plugins/kensobi-spc-panel/versions/2.4.0/images/img/variable-limits.png)
![Feature queries](https://grafana.com/api/plugins/kensobi-spc-panel/versions/2.4.0/images/img/feature-queries.png)
![SPC charts with variable](https://grafana.com/api/plugins/kensobi-spc-panel/versions/2.4.0/images/img/spc-chart-variable-v2.png)
![Dynamic JSON Badge](https://img.shields.io/badge/dynamic/json?logo=grafana\&query=$.version\&url=https://grafana.com/api/plugins/kensobi-spc-panel\&label=Marketplace\&prefix=v\&color=F47A20) ![Grafana](https://img.shields.io/badge/Grafana-11.6%2B-orange?logo=grafana)
The SPC Chart panel automatically calculates and displays control limits for **XmR**, **Xbar-R**, and **Xbar-S** charts — so you can monitor process stability, detect special cause variation, and make data-driven decisions in real time.
![SPC Chart with variable limits and custom control lines](https://raw.githubusercontent.com/KensoBI/spc-chart/refs/heads/main/src/img/spc-chart-variable-v2.png)
## Why SPC Chart?
Control charts are the foundation of statistical process control. They separate **common cause** variation (normal process behavior) from **special cause** variation (signals that something has changed). This plugin makes that analysis effortless:
- **Automatic control limits** — LCL, UCL, and Mean are calculated and displayed automatically based on the selected chart type
- **Multiple chart types** — XmR for individual measurements, Xbar-R for small subgroups, Xbar-S for larger subgroups
- **Custom control lines** — add Nominal, LSL, USL, or any custom reference line with static values or dynamic series lookup
- **Fill regions** — visually highlight zones between control lines to show acceptable process ranges
- **Statistics table** — an optional table below the chart summarizing each series: count, mean, standard deviation, min/max, control limits, and process capability (Cp, Cpk, Pp, Ppk)
![SPC Chart dashboard showing all chart types](https://raw.githubusercontent.com/KensoBI/spc-chart/refs/heads/main/src/img/numeric-x-table.png)
## Features
| Feature                  | Description        |
| XmR charts               | Individual (X) and Moving Range (mR) charts for single measurements                     |
| Xbar-R charts            | Subgroup mean (X-bar) and Range (R) charts for small subgroups                          |
| Xbar-S charts            | Subgroup mean (X-bar) and Standard Deviation (S) charts for larger subgroups            |
| Automatic control limits | LCL, UCL, and Mean calculated from the data using standard SPC formulas                 |
| Custom control lines     | Add Nominal, LSL, USL, or custom lines with static values or dynamic series lookup      |
| Subgrouping              | Group consecutive measurements into subgroups of size 2-25                              |
| Aggregation              | Aggregate raw data by moving range, range, mean, or standard deviation                  |
| Fill regions             | Color-fill areas between control lines to highlight process zones                       |
| Alerting support         | Grafana alerting integration with alert state annotations on the chart                  |
| Custom annotations       | Create, edit, and delete annotations directly on the chart                              |
| Threshold visualization  | Display alert thresholds alongside SPC control limits                                   |
| Dashboard variables      | Control subgroup size across multiple panels with a single `subgroupSize` variable      |
| Feature queries          | Mark queries as reference-only: consumed as control lines, excluded from SPC statistics |
| Variable limits          | Draw a stepped specification limit from a reference query carrying one value per point  |
| Statistics table         | Optional summary table with per-series stats and process capability                     |
## Statistics Table
Turn on **Show statistics table** in the panel options to display a summary table below the chart. For each series it shows the count, mean, standard deviation, min and max of your measurements, the control limits (LCL/UCL), and — when both a Lower and Upper Specification Limit are set — the process capability indices Cp, Cpk, Pp, and Ppk.
You choose which columns appear, and columns that don't apply are hidden automatically. To save the numbers, **right-click the panel and choose "Download CSV"**. The table is off by default, so existing dashboards are unaffected until you enable it.
## Use Cases
- **Manufacturing quality** — monitor process parameters and detect shifts before they produce defects
- **IT operations** — track response times, error rates, or throughput to distinguish real incidents from normal variation
- **Laboratory analysis** — control measurement systems and reagent performance over time
- **Supply chain** — monitor delivery times, fill rates, or inventory levels for process stability
- **Healthcare** — track clinical metrics and patient outcomes with statistical rigor
## Requirements
- Grafana **11.6.10** or later
## Getting Started
1. Install the plugin from the [Grafana Plugin Catalog](https://grafana.com/grafana/plugins/kensobi-spc-panel/)
2. Add a new panel and select **SPC Chart** as the visualization
3. Configure a query that returns time series data (a time field and one or more numeric value fields)
4. Select a **Chart Type** (XmR, Xbar-R, or Xbar-S) to automatically calculate control limits
The plugin comes with sample provisioned dashboards. Build and start the plugin to see them.
## Documentation
For detailed documentation, configuration guides, and formula references, see the [full documentation](https://docs.kensobi.com/panels/spc-chart/).
## Part of the KensoBI SPC Suite
SPC Chart is part of a growing family of **Statistical Process Control** plugins for Grafana by Kenso Software:
**[SPC Histogram Panel](https://grafana.com/grafana/plugins/kensobi-spchistogram-panel/)** — Distribution analysis with histograms, bell curves, and a built-in statistics table showing Cp, Cpk, Pp, and Ppk. Use it to understand process capability: is your process producing results within specification limits?
**[SPC Pareto Panel](https://grafana.com/grafana/plugins/kensobi-spcpareto-panel/)** — Pareto analysis with automatic sorting, cumulative percentage lines, and 80/20 threshold highlighting. Use it to identify the vital few factors contributing to defects or issues.
**[SPC CAD Panel](https://grafana.com/grafana/plugins/kensobi-spccad-panel/)** — Brings 3D geometry into the picture, letting you bind the data from control charts and histograms to physical features on your parts.
**[SPC Box Plot Panel](https://grafana.com/grafana/plugins/kensobi-spcboxplot-panel/)** — Box-and-whisker plots with built-in SPC. Automatically groups measurements into subgroups, computes quartiles and outliers, and overlays Xf-Rf control limits to detect shifts in both process location and spread.
**[SPC Bullet Panel](https://grafana.com/grafana/plugins/kensobi-spcbullet-panel/)** — Compact bullet charts and progress bars with optional SPC metrics (Cpk, Cp, Ppk, Pp, Sigma Level) for dense KPI dashboards.
**[SPC Characteristic Datasource](https://grafana.com/grafana/plugins/kensobi-spccharacteristic-datasource/)** — The datasource that powers the SPC CAD panel. Connects to your measurement database (PostgreSQL or MSSQL), lets you select features and characteristics through a point-and-click interface, and returns SPC statistics, time series measurements, and forecast data — no SQL required.
## Getting Help
If you have any questions or feedback, you can:
- Create an [issue](https://github.com/KensoBI/spc-chart/issues) to report bugs, issues, and feature suggestions.
- Ask a question on the [KensoBI Discord channel](https://discord.gg/cVKKh7trXU).
Your feedback is always welcome!
## License
This software is distributed under the [Apache License 2.0](https://raw.githubusercontent.com/KensoBI/spc-chart/main/LICENSE).
