Plugins 〉Percent+
The Percent+ plugin has been deprecated and is no longer maintained.
Percent+
Grafana percent+ stat panel
Simply computes and display percent given two metric.
Design with heartbeat in minds, it aims to display an availability rate. But you can give it any metric in input to compute your own percent rate.
Install
Download latest release https://github.com/JeanBaptisteWATENBERG/grafana-percent-plus/releases/download/v1.0.6/grafana-percent-plus.zip and unzip it in your grafana plugin folder.
Usage
- Query two metrics
- Use them to display your availability rate
Contibute
To work with this plugin run:
yarn dev
yarn watch
This will run linting tools and apply prettier fix.
To build the plugin run:
yarn build
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Percent+ on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Percent+ from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
