title: "Hubble Process Ancestry panel plugin for Grafana"
description: "Hubble Process Ancestry panel plugin for Grafana. Hubble Process Ancestry panel plugin for Grafana by Isovalent. See install steps and the changelog."
> This is the Markdown version of https://grafana.com/grafana/plugins/isovalent-hubbleprocessancestry-panel/
# Hubble Process Ancestry
- Developer: Isovalent
- Version: 1.0.3
- [Installation](https://grafana.com/grafana/plugins/isovalent-hubbleprocessancestry-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/isovalent-hubbleprocessancestry-panel/changelog.md)
![Hubble Process Ancestry](https://grafana.com/api/plugins/isovalent-hubbleprocessancestry-panel/versions/1.0.3/images/img/screenshots/hubble-process-ancestry-panel-plugin.png)
# Hubble Process Ancestry panel plugin for Grafana
Grafana panel plugin that allows to visualize Hubble Process Ancestry directly in Grafana interface. It requires [Isovalent Cilium Enterprise](https://isovalent.com/product/).
## Requirements
A compatible Grafana datasource plugin is required for this plugin to work. Currently there is Hubble datasource plugin available.
## Usage
On dashboard that supposed to show process ancestry add variable "Pod" that fetches pods list from datasource plugin.
Add panel plugin on dashboard by searching visualization "hubble process ancestry", selecting appropriate datasource plugin, "Process Ancestry" query type and "`${Pod} = ...`" value in "Pod" dropdown.
## Data schema
Currently two data frame types are supported: for `PROCESS_EXEC` and `PROCESS_CONNECT` events.
### `PROCESS_EXEC`
| field                                  | type          | sample        |
| node_name                              | string        | minikube        |
| time                                   | number        | 1675087549022        |
| kind                                   | string        | PROCESS_EXEC        |
| id                                     | string        | minikube/1675087549.22000000/PROCESS_EXEC/bWluaWt1YmU6MjA2NjkwMDAwMDAwOjIzMTU2        |
| process/exec_id                        | string        | bWluaWt1YmU6MjA2NjkwMDAwMDAwOjIzMTU2        |
| process/pid                            | number        | 23156        |
| process/uid                            | number        | 23156        |
| process/cwd                            | string        | /        |
| process/binary                         | string        | /minio-operator        |
| process/arguments                      | string        |        |
| process/flags                          | string        | procFS auid rootcwd        |
| process/start_time                     | number        | 1675087549022        |
| process/auid                           | number        | 0        |
| process/docker                         | string        | 97b5d10913ddc80e4409e715f0c73e2        |
| process/parent_exec_id                 | string        | bWluaWt1YmU6MjA2NjMwMDAwMDAwOjIzMTMy        |
| process/refcnt                         | number        | 0        |
| process/pod/namespace                  | string        | minio        |
| process/pod/name                       | string        | minio-operator-5f4cb79d7c-6rzr6        |
| process/pod/labels                     | string        | k8s:app.kubernetes.io/instance=minio-operator,k8s:app.kubernetes.io/name=operator,k8s:io.cilium.k8s.namespace.labels.kubernetes.io/metadata.name=minio,k8s:io.cilium.k8s.namespace.labels.name=minio,k8s:io.cilium.k8s.policy.cluster=default,k8s:io.cilium.k8s.policy.serviceaccount=minio-operator,k8s:io.kubernetes.pod.namespace=minio,k8s:operator=leader |
| process/pod/container/id               | string        | docker://97b5d10913ddc80e4409e715f0c73e2d77a57d133a88baa6330a3d488202ec45        |
| process/pod/container/name             | string        | operator        |
| process/pod/container/start_time       | 1675087549000 |        |
| process/pod/container/pid              | number        | 1        |
| process/pod/container/maybe_exec_probe | boolean       | false        |
| process/pod/container/image/id         | string        | docker-pullable://minio/operator\@sha256:5f5f31cf46a7683dc37aeaf598baf552640c03ac6fc8f2aac169e015d077e935        |
| process/pod/container/image/name       | string        | minio/operator:v4.5.1        |
| parent/exec_id                         | string        | bWluaWt1YmU6MjA2NjMwMDAwMDAwOjIzMTMy        |
| parent/pid                             | number        | 23132        |
| parent/uid                             | number        | 23132        |
| parent/cwd                             | string        | /run/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/97b5d10913ddc80e4409e715f0c73e2d77a57d133a88baa6330a3d488202ec45        |
| parent/binary                          | string        | /usr/bin/containerd-shim        |
| parent/arguments                       | string        | -namespace moby -workdir /var/lib/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/97b5d10913ddc80e4409e715f0c73e2d77a57d133a88baa6330a3d488202ec45 -address /var/run/docker/containerd/containerd.sock -containerd-binary /usr/bin/containerd -runtime-root /var/run/docker/runtime-runc -systemd-cgroup                                          |
| parent/flags                           | string        | procFS auid        |
| parent/start_time                      | number        | 1675087548962        |
| parent/auid                            | number        | 0        |
| parent/docker                          | string        |        |
| parent/parent_exec_id                  | string        | bWluaWt1YmU6MTI0OTYwMDAwMDAwOjE3NDc1        |
| parent/refcnt                          | number        | 0        |
### `PROCESS_CONNECT`
| time                                   | number        | 1674748552434        |
| kind                                   | string        | PROCESS_CONNECT        |
| id                                     | string        | minikube/1674748552.434000000/PROCESS_CONNECT/bWluaWt1YmU6MTMxMzQwMDAwMDAwOjIwMzA5        |
| process/exec_id                        | string        | bWluaWt1YmU6MTMxMzQwMDAwMDAwOjIwMzA5        |
| process/pid                            | number        | 20309        |
| process/uid                            | number        | 20309        |
| process/start_time                     | 1674748552434 |        |
| process/docker                         | string        | da15ebaf7183a00c0a5e949ad535167        |
| process/parent_exec_id                 | string        | bWluaWt1YmU6MTMxMzIwMDAwMDAwOjIwMjky        |
| process/pod/labels                     | string        |        |
| process/pod/container/id               | string        | docker://da15ebaf7183a00c0a5e949ad5351671936c9a765b0d1a3ef27eed1cfa6e49fc        |
| process/pod/container/start_time       | string        | 1674748552000        |
| process/pod/container/maybe_exec_probe | string        |        |
| process/pod/namespace                  | string?       | minio        |
| process/pod/name                       | string?       | minio-operator-5f4cb79d7c-6rzr6        |
| process/pod/labels                     | string?       |        |
| process/pod/container/id               | string?       | docker://da15ebaf7183a00c0a5e949ad5351671936c9a765b0d1a3ef27eed1cfa6e49fc        |
| process/pod/container/name             | string?       | operator        |
| process/pod/container/start_time       | string?       | 1674748552000        |
| process/pod/container/pid              | number?       | 1        |
| process/pod/container/maybe_exec_probe | boolean?      | false        |
| process/pod/container/image/id         | string?       | docker-pullable://minio/operator\@sha256:5f5f31cf46a7683dc37aeaf598baf552640c03ac6fc8f2aac169e015d077e935        |
| process/pod/container/image/name       | string?       | minio/operator:v4.5.1        |
| parent/exec_id                         | string        | bWluaWt1YmU6MTMxMzIwMDAwMDAwOjIwMjky        |
| parent/pid                             | number        | 20292        |
| parent/uid                             | number        | 20292        |
| parent/cwd                             | string        | /run/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/da15ebaf7183a00c0a5e949ad5351671936c9a765b0d1a3ef27eed1cfa6e49fc        |
| parent/arguments                       | string        | -namespace moby -workdir /var/lib/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/da15ebaf7183a00c0a5e949ad5351671936c9a765b0d1a3ef27eed1cfa6e49fc -address /var/run/docker/containerd/containerd.sock -containerd-binary /usr/bin/containerd -runtime-root /var/run/docker/runtime-runc -systemd-cgroup |
| parent/start_time                      | 1674748552414 |        |
| parent/parent_exec_id                  | string        | bWluaWt1YmU6OTcyOTAwMDAwMDA6MTIyNTc=        |
| source_ip                              | string        | 10.88.0.38        |
| source_port                            | number        | 55142        |
| destination_ip                         | string        | 10.96.0.1        |
| destination_port                       | string        | 443        |
| destination_names                      | string        |        |
| sock_cookie                            | number        | 0        |
| protocol                               | number        | 6        |
