title: "Pareto Chart panel plugin for Grafana"
description: "Pareto Chart for Grafana. Pareto Chart panel plugin for Grafana by isaozler. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/isaozler-paretochart-panel/
# Pareto Chart
- Developer: isaozler
- Version: 0.3.4
- [Installation](https://grafana.com/grafana/plugins/isaozler-paretochart-panel/installation.md)
![Pareto Chart Dashboard Impression](https://grafana.com/api/plugins/isaozler-paretochart-panel/versions/0.3.4/images/img/production-env--impression.jpg)
![Pareto Chart Edit Dashboard](https://grafana.com/api/plugins/isaozler-paretochart-panel/versions/0.3.4/images/img/pareto-chart-edit-panel.jpg)
# Grafana Pareto Panel Plugin
![Edit Panel](https://raw.githubusercontent.com/isaozler/pareto-chart/releases/latest/src/img/pareto-chart-edit-panel.jpg)
This plugin provides you the ability to draw a Pareto chart with `RDB` and `TimeSeries databases`.
## Features
- Setting a custom background color to the tooltip overlay
- Configurable vital few and trivial many lines
- Pan and zoom for detailed info without changing date range
- Set decimals count on displayed values
- Specify bar spacing
- Quickly copy bar data to clipboard simply by clicking on the bar
- Option to show/hide bar values on default
- Style graphs to need
# TimeSeries (InfluxDB) dashboard impression
![Dashboard impression](https://raw.githubusercontent.com/isaozler/pareto-chart/releases/latest/src/img/production-env--impression.jpg)
## MySQL Example
Provide the `defects` which could be "categories" (type **string**) for example and a `frequency` value cummulatives/counts (type **number**).
\| Defects | Counts | | :-: | :-: | | Error 1 | 10 | | Error 2 | 4 | | Error 3 | 1 | | ... | ... |
## Example Query
```sql
SELECT _label_, _count_, ...
FROM _table_
