Plugins 〉SurrealDB
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
SurrealDB
- Overview
- Installation
- Change log
- Related content
SurrealDB Datasource
The SurrealDB datasource plugin enables you to query and visualize SurrealDB data directly within Grafana, offering seamless integration and exploration of SurrealDB datasets.
⚠️ This plugin is currently experimental
This means that while we believe in its potential and are enthusiastic about its development, we are not yet ready to make a long-term commitment to maintaining it indefinitely. The plugin is still under active development and may contain bugs. We do not recommend using this plugin in production environments.
Usage
Installation
Please refer to our Data Source Management documentation for more information on installing the plugin to an instance of Grafana.
Configuration
Add a data source by filling in the following fields:
Basic fields
Field | Description |
Endpoint URL | The full address of the SurrealDB RPC endpoint to connect to, e.g. ws://localhost:8000/rpc |
Database name | The name of the database to connect to. |
Namespace | The namespace to use for the connection. |
Authentication fields
Username | Your SurrealDB username |
Password | Your SurrealDB password |
Scope | The scope to use for the user. (Optional) |
We strongly recommend that you make your queries with a user account that has read-only access. This practice not only safeguards your data but also helps maintain system integrity.
Querying
The query editor allows you to write SurrealQL queries. For more information about writing SurrealQL queries, please refer to SurrealDB's documentation.
In this version, only a SurrealQL Editor is provided to write queries with. A Query Builder UI is planned for a later version of the plugin.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing SurrealDB on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install SurrealDB from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
0.2.5
- Dependency updates.
0.2.4
0.2.3
- Add compatibility warning for SurrealDB v2.0.
0.2.2
- Updates to error source capture.
0.2.1
0.2.0
- Added support for Grafana macros.
- Added
QueryWithContext
method to better handle context cancellation and timeouts. - Added error source and metrics capture (internally used by Grafana Cloud).
- Added integration tests.
- Bump Go to 1.22.6.
0.1.2
- Fixed Alerting support not activated.
- Go version update to 1.21.6.
0.1.1
- Added
README.md
file tosrc
directory for display on Grafana plugin page.
0.1.0
Initial experimental release.
