title: "Pie Chart panel plugin for Grafana"
description: "Pie chart panel for grafana. Pie Chart panel plugin for Grafana by Grafana Labs. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/grafana-piechart-panel/
# Pie Chart
- Developer: Grafana Labs
- Version: 1.6.4
- [Change log](https://grafana.com/grafana/plugins/grafana-piechart-panel/changelog.md)
![Donut!](https://grafana.com/api/plugins/grafana-piechart-panel/versions/1.6.4/images/img/piechart-donut.png)
![Legend on the graph](https://grafana.com/api/plugins/grafana-piechart-panel/versions/1.6.4/images/img/piechart-legend-on-graph.png)
![Legend to the right](https://grafana.com/api/plugins/grafana-piechart-panel/versions/1.6.4/images/img/piechart-legend-rhs.png)
![Legend underneath](https://grafana.com/api/plugins/grafana-piechart-panel/versions/1.6.4/images/img/piechart-legend-under.png)
![Piechart options](https://grafana.com/api/plugins/grafana-piechart-panel/versions/1.6.4/images/img/piechart-options.png)
# **Notice:** This plugin is deprecated
[![Marketplace](https://img.shields.io/badge/dynamic/json?logo=grafana\&color=F47A20\&label=marketplace\&prefix=v\&query=%24.items%5B%3F%28%40.slug%20%3D%3D%20%22grafana-piechart-panel%22%29%5D.version\&url=https%3A%2F%2Fgrafana.com%2Fapi%2Fplugins)](https://grafana.com/grafana/plugins/grafana-piechart-panel) [![Downloads](https://img.shields.io/badge/dynamic/json?logo=grafana\&color=F47A20\&label=downloads\&query=%24.items%5B%3F%28%40.slug%20%3D%3D%20%22grafana-piechart-panel%22%29%5D.downloads\&url=https%3A%2F%2Fgrafana.com%2Fapi%2Fplugins)](https://grafana.com/grafana/plugins/grafana-piechart-panel) [![License](https://img.shields.io/github/license/grafana/piechart-panel)](https://grafana.com/grafana/plugins/grafana-piechart-panel/LICENSE) [![Known Vulnerabilities](https://snyk.io/test/github/grafana/piechart-panel/badge.svg)](https://snyk.io/test/github/grafana/piechart-panel) [![Build Status](https://drone.grafana.net/api/badges/grafana/piechart-panel/status.svg)](https://drone.grafana.net/grafana/piechart-panel)
As of [Grafana 8.0](https://grafana.com/docs/grafana/latest/whatsnew/whats-new-in-v8-0/#whats-new-in-grafana-v80) Pie chart panel is included with Grafana. Please refer to the [Pie chart panel](https://grafana.com/docs/grafana/latest/visualizations/pie-chart-panel/) documentation for more information.
## Installation
Use the new grafana-cli tool to install piechart-panel from the commandline:
```SHELL
grafana-cli plugins install grafana-piechart-panel
The plugin will be installed into your Grafana plugins directory; the default is /var/lib/grafana/plugins if you installed the Grafana package.
More instructions on the Grafana CLI tool can be found in [Grafana CLI](https://grafana.com/docs/grafana/latest/administration/cli/).
You must have Grafana 4.6.5 or newer installed to run this plugin. You can get it here: <https://grafana.com/grafana/download>
## Alternative installation methods
### Download latest zip
```BASH
wget -nv https://grafana.com/api/plugins/grafana-piechart-panel/versions/latest/download -O /tmp/grafana-piechart-panel.zip
Extract and move into place
```BASH
unzip -q /tmp/grafana-piechart-panel.zip -d /tmp
mv /tmp/grafana-piechart-panel-* /var/lib/grafana/plugins/grafana-piechart-panel
sudo service grafana-server restart
### Git clone
You can clone this repo directly into your plugins directory.
Afterwards restart grafana-server and the plugin should be automatically detected and used.
```SHELL
git clone https://github.com/grafana/piechart-panel.git --branch release-1.6.2
### Clone into a directory of your choice
If the plugin is cloned to a directory that is not the default plugins directory, then you need to edit your grafana.ini config file (default location is at /etc/grafana/grafana.ini) and add this:
```ini
[plugin.piechart]
path = /home/your/clone/dir/piechart-panel
Note that if you clone it into the Grafana plugins directory, then you do not need to add the above config option. That is only if you want to place the plugin in a directory outside the standard plugins directory. Make sure that grafana-server has read access to the directory.
