Plugins 〉DynamoDB
Developer
Grafana Labs
Data Source
grafana
Enterprise
DynamoDB
Documentation →
DynamoDB data source for Grafana
The DynamoDB data source allows a direct connection to DynamoDB to query and visualize data in Grafana.
This data source supports PartiQL query syntax and provides an editor to format and color code your PartiQL statements.
See also
Technical documentation
License
Installing DynamoDB on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install DynamoDB from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v2.1.6 - 2025-02-12
  • ⚙️ Chore: Update dependencies
v2.1.5 - 2025-01-30
  • ⚙️ Chore: Add ARN warning
v2.1.4 - 2025-01-20
v2.1.3 - 2025-01-06
  • ⚙️ Chore: update backend dependencies
v2.1.2 - 2024-12-13
  • ⚙️ Chore: Update backend dependencies
v2.1.1 - 2024-11-22
v2.1.0 - 2024-10-22
  • ⚙️ Chore: Update backend and frontend dependencies
  • ⚙️ Chore: Minimal supported Grafana version is now 10.4.8
v2.0.1 - 2024-10-15
  • ⚙️ Chore: Update settings
v2.0.0 - 2024-10-08
  • 🚀 Feature: Update AWS Auth component in config page
  • 🚀 Feature: Support session token configuration with AWS credentials file
  • BREAKING CHANGE: This release includes a breaking change config page. Should you update the config page, you may lose Access Secret Key. Ensure to have Access Key and Access Secret key to update the config page.
v1.1.3 - 2024-09-29
v1.1.2 - 2024-09-18
v1.1.1 - 2024-09-18
  • ⚙️ Chore: add errorsource
v1.1.0 - 2024-09-12
  • 📝 Documentation: Update docs
v1.0.5 - 2024-09-10
v1.0.4 - 2024-09-09
v1.0.3 - 2024-08-19
  • ⚙️ Chore: update frontend dependencies
v1.0.2 - 2024-07-10
  • 📝 Fix: Fix license check
v1.0.1 - 2024-06-21
  • 📝 Documentation: Remove BETA from the readme
v1.0.0 - 2024-06-20
  • ⚙️ Chore: Stable release
v0.1.1-beta
  • Initial beta version
