Plugins 〉Catchpoint
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Catchpoint
- Overview
- Installation
- Change log
- Related content
- Documentation →
Grafana Catchpoint data source plugin
The Catchpoint data source plugin allows you to query Tests, SLO, RUM data.
Project status
NOTE: This plugin is in a public preview. Refer Grafana Labs release life cycle documentation for further details. If you notice any issues or having feature request, create a support ticket with your Grafana Enterprise support channel.
See also
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Catchpoint on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Catchpoint from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v0.1.5-preview - 2025-02-10
- ⚙️ Chore: Update backend dependencies
v0.1.4-preview - 2024-09-03
v0.1.3-preview
v0.1.2-preview
- ⚙️ Chore: backend binaries are now compiled with go 1.22.5
v0.1.1-preview
- ⚙️ Chore: Update documentation
v0.1.0-preview
- 🚀 Feature: Initial release
