Google BigQuery data source for Grafana
The Google BigQuery data source plugin allows you to query and visualize Google BigQuery data from within Grafana.
Documentation
For complete documentation, refer to Google BigQuery data source documentation.
- Configure the data source — Authentication, provisioning, and Terraform setup
- Query editor — SQL and visual query editors, macros, partitioned tables
- Template variables — Dynamic dashboards with BigQuery queries
- Annotations — Overlay events on your graphs
- Alerting — Create alert rules using BigQuery data
- Troubleshooting — Solve common issues
Installation
- Navigate to the BigQuery plugin page on Grafana.
- Click Install plugin.
For detailed installation and configuration instructions, refer to Configure the data source.
Requirements
The following Google APIs must be enabled in your GCP project:
Get help
- ...and more
Insights
- Adoption
Running on 25,064 active Grafana instances.
- Activity
Last updated 30 Oct 2026.
18 releases in the past year.
- Queries
205,851,073 total queries served across all Grafana Cloud instances.
- Version
- 3.4.7
- Dependencies
- Grafana >=11.6.11-0 <12 || >=12.0.10-0 <12.1 || >=12.1.7-0 <12.2 || >=12.2.5-0
- Developer
- Grafana Labs
- ...and more
