title: "Azure Monitor data source plugin for Grafana"
description: "Data source for Microsoft Azure Monitor & Application Insights. Azure Monitor data source plugin for Grafana by Grafana Labs."
> This is the Markdown version of https://grafana.com/grafana/plugins/grafana-azure-monitor-datasource/
# Azure Monitor
- Developer: Grafana Labs
- Version: 13.0.8
- [Installation](https://grafana.com/grafana/plugins/grafana-azure-monitor-datasource/installation.md)
- [Change log](https://grafana.com/grafana/plugins/grafana-azure-monitor-datasource/changelog.md)
![Azure Contoso Loans](https://grafana.com/api/plugins/grafana-azure-monitor-datasource/versions/13.0.8/images/img/contoso_loans_grafana_dashboard.png)
![Azure Monitor Network](https://grafana.com/api/plugins/grafana-azure-monitor-datasource/versions/13.0.8/images/img/azure_monitor_network.png)
![Azure Monitor CPU](https://grafana.com/api/plugins/grafana-azure-monitor-datasource/versions/13.0.8/images/img/azure_monitor_cpu.png)
# Azure Monitor data source - native plugin
Grafana ships with **built in** support for Azure Monitor. You just have to add it as a data source and you will be ready to build dashboards for your Azure Monitor metrics.
Read more about it here:
<https://grafana.com/docs/grafana/latest/datasources/azuremonitor/>
