title: "WindRose panel plugin for Grafana"
description: "Make windrose plots. WindRose panel plugin for Grafana by fatcloud. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/fatcloud-windrose-panel/
# WindRose
- Developer: fatcloud
- Version: 0.7.1
![Showcase](https://grafana.com/api/plugins/fatcloud-windrose-panel/versions/0.7.1/images/img/twocharts.png)
![Options](https://grafana.com/api/plugins/fatcloud-windrose-panel/versions/0.7.1/images/img/windroseoptions.png)
## Windrose Panel for Grafana
Render metrics into a windrose chart.
### Screenshots
![](https://i.imgur.com/ADjvKwA.png)
![](https://i.imgur.com/HXLgwLB.png)
### Environments
For linux ubuntu 16.04, first get nvm installed. some instructions can be found [here](https://www.digitalocean.com/community/tutorials/how-to-install-node-js-on-ubuntu-16-04).
After nvm installation, activate one engine. Here version 8.x is picked for no particular reason.
nvm install v8
nvm use v8
### Building
To complie, run:
npm install -g yarn
yarn install --pure-lockfile
grunt
### Roadmap
- This plugin is modified from [plotly panel for grafana](https://github.com/NatelEnergy/grafana-plotly-panel) and currently has many inconsistent variable names to be refactored.
### Authors and contributors
The Grafana Windrose Plugin was initiated as a part of the joint research project among RCAS, RCEC of Academia Sinica of Taiwan; NCHC, TORI of Natioanl Applied Research Laboratories of Taiwan and Taiwan Generations Corporation.  It was developed by Sea Bunny Corporation and released under MIT license.
The contacts of developers are
Chih-Yu Kuo Research Fellow, RCAS, Academia Sinica, Taipei, Taiwan <cykuo06@gate.sinica.edu.tw>
and
Chun-Yun Wang, Sea Bunny Corporation, Taipei, Taiwan. <cloud@seabunny.tech>
RCAS: Research Center for Applied Sciences, RCEC: Research Center for Environmental Changes, NCHC: National Center for High-performance Computing, TORI: Taiwan Ocean Research Institute.
The code based is modified from a fork of [plotly panel for grafana](https://github.com/NatelEnergy/grafana-plotly-panel).
