title: "ESnet Matrix Panel plugin for Grafana"
description: "Matrix Panel Plugin that allows comparison of two non-timeseries categories. ESnet Matrix Panel plugin for Grafana by esnet."
> This is the Markdown version of https://grafana.com/grafana/plugins/esnet-matrix-panel/
# ESnet Matrix Panel
- Developer: esnet
- Version: 2.1.0
- [Installation](https://grafana.com/grafana/plugins/esnet-matrix-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/esnet-matrix-panel/changelog.md)
![matrix-plugin](https://grafana.com/api/plugins/esnet-matrix-panel/versions/2.1.0/images/img/matrix-plugin.png)
![matrix-plugin2](https://grafana.com/api/plugins/esnet-matrix-panel/versions/2.1.0/images/img/matrix-plugin2.png)
# Matrix Panel Plugin
This plugin creates a 2D matrix showing the relationship between 2 selected fields (source and target). Note: This is NOT inteded to use with time series data or large data sets. It also will not render if there are >200 rows or columns
![](https://github.com/esnet/esnet-matrix-panel/blob/master/src/img/matrix-plugin.png?raw=true)
## Options
### Display
**Show Legend:** Adds legend to bottom of panel.
**Legend Type:** There are two types. Categorical will produce a legend with distinct colors for each unique detected value. Range will generate a bar with the detected range of colors & values.
**Source Field:** The field you want to use on the vertical axis.
**Target Field:** The field you want to use on the horizontal axis.
**Value Field:** The metric you want to use to color the boxes.
**Source/Target/Value Text:** The text to appear in the tool tip.
**Cell Size:** The size of each square. This number sets the width of the square in pixels.
**Cell Padding:** The relative padding between each square.
**Text Length:** The max number of characters to include before truncating the label. Using a smaller number here can help prevent
**Text Size:** The size of the text labels
**Null Color:** The color to use for a square when "null" is returned by the query
**No Data Color:** The color to use for a square when there is no value returned by the query for the specified source and target pair.
### Colors
The color of each square will be determined by the selected metric and the color choice in the **Standard Options**.
