Matrix Panel Plugin
This plugin creates a 2D matrix showing the relationship between 2 selected fields (source and target). Note: This is NOT inteded to use with time series data or large data sets. It also will not render if there are >200 rows or columns
Options
Display
Show Legend: Adds legend to bottom of panel.
Legend Type: There are two types. Categorical will produce a legend with distinct colors for each unique detected value. Range will generate a bar with the detected range of colors & values.
Source Field: The field you want to use on the vertical axis.
Target Field: The field you want to use on the horizontal axis.
Value Field: The metric you want to use to color the boxes.
Source/Target/Value Text: The text to appear in the tool tip.
Cell Size: The size of each square. This number sets the width of the square in pixels.
Cell Padding: The relative padding between each square.
Text Length: The max number of characters to include before truncating the label. Using a smaller number here can help prevent
Text Size: The size of the text labels
Null Color: The color to use for a square when "null" is returned by the query
No Data Color: The color to use for a square when there is no value returned by the query for the specified source and target pair.
Colors
The color of each square will be determined by the selected metric and the color choice in the Standard Options.
- ...and more
Insights
- Adoption
Running on 4,304 active Grafana instances.
- Activity
Last updated 4 Jun 2026.
2 releases in the past year.
- Version
- 2.1.0
- Dependencies
- Grafana >=12.3.0
- Developer
- esnet
- ...and more
