title: "ESnet Chord panel plugin for Grafana"
description: "ESnet Chord Panel Plugin for Grafana 8.3 and newer. ESnet Chord panel plugin for Grafana by esnet. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/esnet-chord-panel/
# ESnet Chord
- Developer: esnet
- Version: 1.0.5
- [Installation](https://grafana.com/grafana/plugins/esnet-chord-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/esnet-chord-panel/changelog.md)
![chord-example](https://grafana.com/api/plugins/esnet-chord-panel/versions/1.0.5/images/img/Chord-Example.png)
# Chord Panel Plugin
This is a panel plugin for generating Chord diagrams in Grafana 8.3+. This plugin uses a locally included version of [d3](https://github.com/d3/d3).
![Screenshot](https://github.com/esnet/grafana-esnet-chord-panel/blob/main/src/img/Chord-Example.png?raw=true)
## Data
This plugin uses non time series data and requires each row to have 2 data fields and a metric or value field.
**NOTE**: If the panel is blank even though your data input is correct, it may be too small. Try resizing the panel until it is large enough to display the chord diagram.
## Customizing
### Display
Source Field: The query field to use as the source of the chord.
Target Field: The query field to use as the target of the chord.
Value Field: The query field (usually the metric) to be used to determine the thickness of the each chord.
Text Length: The amount of space alloted for labels on the outside of the diagram.
### Standard
Units: Set the units for the values in the Standard Options section.
