title: "Split Flap panel plugin for Grafana"
description: "A retro-style Split Flap display panel for Grafana. Perfect for visualizing counters, metrics, and status codes with a classic airport terminal aesthetic."
> This is the Markdown version of https://grafana.com/grafana/plugins/dzaczek-splitflap-panel/
# Split Flap
- Developer: dzaczek
- Version: 2.4.3
- [Installation](https://grafana.com/grafana/plugins/dzaczek-splitflap-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/dzaczek-splitflap-panel/changelog.md)
![Split Flap Panel](https://grafana.com/api/plugins/dzaczek-splitflap-panel/versions/2.4.3/images/img/logo.svg)
# Split Flap Panel for Grafana
![Split Flap Logo](https://raw.githubusercontent.com/dzaczek/grafana-splitflap-panel/main/src/img/logo.svg)
A retro-style **Split Flap** display panel for Grafana.
It brings the classic mechanical look of airport departure boards (Solari boards) to your dashboards. I built this to offer a high-quality, animated visualization that feels "real"—with proper physics for the flaps and smooth animations. Perfect for status boards, KPIs, or just making your dashboard look awesome.
## Features
### 🕒 Clock Mode
Turn your dashboard into a stylish world clock.
- **Standalone**: Does not require any data source.
- **Timezones**: Support for all major world timezones (400+ timezones available).
- **Formats**: 12h/24h options, show/hide seconds.
- **Time Separator**: Choose between Colon (:), Dot (.), Dash (-), Space ( ), or None.
- **Date Format**: Optional date display (DD/MM/YYYY, MM/DD/YYYY, YYYY-MM-DD, DD.MM.YYYY).
- **Day of Week**: Optionally display the current day name (short format).
### 🔄 Smart Animation
The flip logic isn't just random:
- **Numbers**: Flip fast using a numeric-only path (e.g., 1 -> 2 is quick).
- **Text**: Goes through the full alphabet cycle, just like the real mechanical ones.
- **Physics**: Long flips accelerate and then slow down at the end (easing).
### 🎨 Themes
Comes with a bunch of built-in styles so you don't have to write CSS:
| Theme                   | Description                                            | Best For                |
| **Classic**             | Standard dark grey, flat look.                         | General use             |
| **Classic 3D**          | Like Classic but with more depth and shadows.          | Realistic look          |
| **Aviation: Departure** | Classic airport board style with yellow text on black. | Flight departure boards |
| **Aviation: Cockpit**   | Technical instrument style with cyan text.             | Aircraft cockpits       |
| **Aviation: Tarmac**    | Orange/amber high-visibility style.                    | Ground operations       |
| **Swiss SBB: Black**    | Swiss railway black display style.                     | Transportation          |
| **Swiss SBB: White**    | Swiss railway white display style.                     | Transportation          |
| **Swiss SBB: Blue**     | Swiss railway blue with red border.                    | Transportation          |
| **Airport**             | Gold text on black background.                         | Flight boards           |
| **Mechanical**          | White/Metal industrial style.                          | IoT / Machinery         |
| **Cyberpunk**           | Neon cyan with CRT scanlines.                          | Sci-fi dashboards       |
| **Matrix**              | Actual digital rain animation in the background.       | Hacker vibes            |
| **Neon**                | Dark background with heavy text glow.                  | Night mode              |
| **E-Ink**               | High contrast, paper-like with vignette.               | E-readers look          |
| **Glass**               | Frosted glass effect with transparency.                | Modern UI               |
| **Blue Glass**          | Blue-tinted glass effect.                              | Modern UI               |
| **Rainbow**             | Colorful gradient display.                             | Colorful dashboards     |
| **Newspaper**           | Halftone newspaper print style.                        | Vintage look            |
| **iOS Light**           | Apple iOS light mode style.                            | Modern Apple-style UI   |
| **iOS Dark**            | Apple iOS dark mode style.                             | Modern Apple-style UI   |
| **Wood**                | Wooden texture style.                                  | Natural/organic look    |
| **Red 3D**              | Red 3D gradient style.                                 | Alerts / Warnings       |
### 📊 Data Options
| Option                | What it does        |
| **Value Aggregation** | Pick what to show from the series: `Last`, `First`, `Min`, `Max`, `Mean`, `Sum`, `Count`, etc. |
| **Main Content**      | Choose what goes on the flaps: `Value`, `Name`, `Name + Value`, or `Value + Name`.             |
| **Auto Fit**          | Automatically calculates the best card size to fit the panel. Turn off for fixed size.         |
| **Name Position**     | Position of series name: Top, Bottom, Left, or Right.                                          |
| **Name Alignment**    | Alignment of series name: Start, Center, or End.                                               |
| **Name Font Size**    | Custom font size for series name (8-100px).                                                    |
| **Unit Position**     | Position of unit: Top, Bottom, Left, Right, or None.                                           |
| **Unit Alignment**    | Alignment of unit: Start, Center, or End.                                                      |
| **Unit Rotation**     | Rotate unit text 90 degrees.        |
| **Custom Unit**       | Override the unit with custom text.                                                            |
| **Unit Font Size**    | Custom font size for unit (8-100px).                                                           |
## Examples
See the panel in action with different configurations:
### Default View
![Split Flap Panel Example](https://raw.githubusercontent.com/dzaczek/grafana-splitflap-panel/main/src/img/example_1.jpg) _Shows numeric values with the classic airport look._
## Usage
1. **Add it**: Find "Split Flap" in the visualization list.
2. **Choose Mode**:
   - **Data Series**: Connect a data source to visualize metrics.
   - **Clock**: Display current time for any timezone (no data source needed).
3. **Tweak it**:
   - Change layout (Vertical/Horizontal).
   - Pick a theme that fits your dashboard.
   - Set up **Thresholds** to change colors dynamically (e.g., red when value > 80).
## Configuration
### Panel Options
| Setting              | Description                                                          | Default     |
| **Mode**             | Choose between `Data Series` or `Clock`.                             | Data Series |
| **Layout**           | Direction of the series grid (Horizontal / Vertical).                | Horizontal  |
| **Show Separators**  | Draw lines between different series.                                 | Off         |
| **Theme**            | Visual style of the flaps (see Themes section above).                | Classic     |
| **Show Name**        | Display series name outside the flaps.                               | On          |
| **Name Position**    | Where to place the name: Top, Bottom, Left, or Right.                | Top         |
| **Name Alignment**   | How to align the name: Start, Center, or End.                        | Center      |
| **Name Font Size**   | Font size for the name (8-100px).                                    | 18          |
| **Show Unit**        | Display unit outside the flaps.                                      | On          |
| **Unit Position**    | Where to place the unit: Top, Bottom, Left, Right, or None.          | Right       |
| **Unit Alignment**   | How to align the unit: Start, Center, or End.                        | Center      |
| **Unit Rotation**    | Rotate unit text 90 degrees.                                         | Off         |
| **Custom Unit**      | Override the unit with custom text.                                  | (empty)     |
| **Unit Font Size**   | Font size for the unit (8-100px).                                    | 24          |
| **Threshold Target** | What to colorize: Text, Tile (card background), or Panel background. | None        |
### Clock Options (Clock Mode Only)
| **12-Hour Format**     | Use 12-hour format (AM/PM) instead of 24-hour.                                               | Off           |
| **Show Seconds**       | Display seconds in the time.        | On            |
| **Timezone**           | Select timezone (400+ available) or use browser local time.                                  | Browser Local |
| **Show Timezone**      | Display timezone name (e.g., "EST", "PST", "UTC") outside the clock.                         | Off           |
| **Timezone Position**  | Where to place the timezone: Top, Bottom, Left, or Right.                                    | Bottom        |
| **Timezone Alignment** | How to align the timezone: Start, Center, or End.                                            | Center        |
| **Timezone Font Size** | Font size for the timezone (8-100px).                                                        | 18            |
| **Time Separator**     | Character between hours, minutes, seconds: Colon (:), Dot (.), Dash (-), Space ( ), or None. | Colon         |
| **Date Format**        | Optional date display format: DD/MM/YYYY, MM/DD/YYYY, YYYY-MM-DD, DD.MM.YYYY, or None.       | None          |
| **Show Day of Week**   | Display abbreviated day name (Mon, Tue, etc.).                                               | Off           |
| **AM/PM Position**     | Position of AM/PM indicator: In Text (Default), Left, or Right.                              | In Text       |
| **AM/PM Orientation**  | Orientation of AM/PM: Horizontal or Vertical.                                                | Horizontal    |
| **AM/PM Font Size**    | Font size for AM/PM indicator.                                                               | 18            |
| **AM/PM Gap**          | Spacing between AM/PM and the clock digits.                                                  | 12            |
### Flip Options
| **Digits**     | Minimum number of characters/cards to show.    | 6       |
| **Rounding**   | Decimal places for numbers.                    | 1       |
| **Auto Fit**   | Auto-scale card size to fill the panel.        | On      |
| **Size (px)**  | Fixed card height (if Auto Fit is off).        | 50      |
| **Gap**        | Space between individual cards.                | 4       |
| **Speed**      | Animation speed multiplier (0.1-2.0).          | 0.49    |
| **Fast Speed** | Speed for quick number transitions (0.05-0.5). | 0.1     |
