title: "Alpine Clock Panel plugin for Grafana"
description: "The most geeky clock panel ever for Grafana: build a watch-style clock from hand geometry and numerals to… Alpine Clock Panel plugin for Grafana by dzaczek."
> This is the Markdown version of https://grafana.com/grafana/plugins/dzaczek-alpineclock-panel/
# Alpine Clock Panel
- Developer: dzaczek
- Version: 1.5.4
- [Installation](https://grafana.com/grafana/plugins/dzaczek-alpineclock-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/dzaczek-alpineclock-panel/changelog.md)
![Paradox of Plenty — 108 themed clocks](https://grafana.com/api/plugins/dzaczek-alpineclock-panel/versions/1.5.4/images/img/screenshot-paradox-of-plenty.png)
![Grand Central Terminal clock](https://grafana.com/api/plugins/dzaczek-alpineclock-panel/versions/1.5.4/images/img/screenshot-grand-central.png)
![Big Ben Elizabeth Tower clock](https://grafana.com/api/plugins/dzaczek-alpineclock-panel/versions/1.5.4/images/img/screenshot-big-ben.png)
![Night Driver dashboard with GM hand](https://grafana.com/api/plugins/dzaczek-alpineclock-panel/versions/1.5.4/images/img/screenshot-night-driver.png)
![Panel configuration UI](https://grafana.com/api/plugins/dzaczek-alpineclock-panel/versions/1.5.4/images/img/screenshot-config.png)
![Alpine Clock Panel logo](https://raw.githubusercontent.com/dzaczek/grafana-alpine-clock-panel/main/src/img/logo.svg)
Alpine Clock Panel is a configurable analog clock plugin for Grafana with watch-inspired styling, timezone support, metric-driven complications, and rich visual customization.
## Highlights
- Configurable dial shapes, gradients, bezels, tick marks, numerals, and hand styles
- Timezone-aware rendering with optional dashboard time synchronization
- Stop-to-go second hand, animated bounce, and dynamic hand shadows
- Date/day windows, rolling date strip, four subdials, and a global metric hand
- Showcase dashboard with multiple design presets and TestData scenarios
## Requirements
- Grafana 12.3.0 or newer
- Node.js version from the repository `.nvmrc` for local development
## Getting started
1. Install dependencies with `npm install`.
2. Start development mode with `npm run dev`.
3. Start Grafana locally with `npm run server`.
4. Open `http://localhost:3000` and add the Alpine Clock Panel to a dashboard.
## Documentation
- Repository and full setup guide: <https://github.com/dzaczek/grafana-alpine-clock-panel>
- Full configuration reference: <https://github.com/dzaczek/grafana-alpine-clock-panel/blob/main/docs/CONFIGURATION.md>
- Local showcase dashboard: `provisioning/dashboards/showcase.json`
## Contributing
Issues and pull requests are welcome in the GitHub repository: <https://github.com/dzaczek/grafana-alpine-clock-panel>
