title: "Sensor Floor Map panel plugin for Grafana"
description: "Colours the rooms of an SVG floor plan by live temperature and humidity against per-sensor limits. Sensor Floor Map panel plugin for Grafana by dkhoa."
> This is the Markdown version of https://grafana.com/grafana/plugins/dkhoa-sensorfloormap-panel/
# Sensor Floor Map
- Developer: dkhoa
- Version: 0.2.2
- [Installation](https://grafana.com/grafana/plugins/dkhoa-sensorfloormap-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/dkhoa-sensorfloormap-panel/changelog.md)
![Demo dashboard](https://grafana.com/api/plugins/dkhoa-sensorfloormap-panel/versions/0.2.2/images/img/screenshot.png)
Draws a floor plan from SVG and colours each room by its live sensor readings (temperature, humidity, CO₂ or any other metric), judged against each sensor's own limits.
## Features
- **Built-in floor plan editor.** Draw rooms, generate one per sensor location from the query, or let the AI assistant draw or trace a plan from a description, an image or a PDF.
- **Any floor plan.** You can also paste SVG: tag room shapes with `data-room="Name"`, or give them an id of `room-Name`. The markup is sanitised before it is shown.
- **Any data source.** Reads tables (one row per reading, with a sensor column) and labelled series such as InfluxDB/Flux results. Field names are detected automatically or can be set by hand.
- **Status at a glance.** Each room is within limits, near a limit, out of limits, offline (no recent reading) or without a sensor. Rooms can also be coloured by where the temperature or humidity sits inside its band.
- **Any metric.** Every numeric field is a metric. Units, decimals and limits come from Grafana's field config and overrides, or from the data per sensor. Temperature, humidity, CO₂, PM2.5 and PM10 have sensible defaults.
- **Sensor binding** by name, or by picking a sensor for each room in the options pane.
- **Hover** for the full reading. **Click** a room to open a URL that can use dashboard variables plus `${room}`, `${sensor}` and `${location}`.
## Getting started
1. Add the panel. It shows a small demo office plan until you draw your own with **Plan drawing → Edit floor plan**.
2. Query your sensor data. The newest reading of each sensor is used.
3. Rooms whose name matches a sensor's location or id are bound automatically. Bind the rest under **Rooms → Sensor per room**.
Full documentation: <https://github.com/dkhoa-dev/grafana-sensor-floor-map#readme>
