Organisations
Panel
Organisations Panel for Grafana
  • Showcase
    Showcase
Organisations Panel Plugin for Grafana
This is a panel plugin for Grafana. It shows all organizations that user belongs to as navigable links.
To understand what is a plugin, read the Grafana's documentation about plugins.
NOTE: Latest version of this panel works only with Grafana >=5.0. Use older panel version with older Grafana version.
Features
Compiling
npm install
grunt
The compiled product is in dist folder.
Deployment
Copy the contents of dist folder to plugins/organisations folder so Grafana will find the plugin and it can be used in Grafana dashboards.
Install the Panel
Use the grafana-cli tool to install Organisations from the commandline:
grafana-cli plugins install digiapulssi-organisations-panel
The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins.
Sign in to install
Version
  • Grafana 6.x.x
