Plugins 〉Chartwerk
Developer
CorpGlory Inc.
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Panel
community
Chartwerk
  • Overview
  • Installation
  • Change log
  • Related content
Grafana Chartwerk Panel (beta)
Grafana Chartwerk Panel renders metrics using Chartwerk libraries. For now, it can render as Gauge. We are working on adding new visualizations.
Features
  • 3 types of visualizations:
    • Gauge
    • Line Chart (coming soon)
    • Bar Chart (coming soon)
  • Gauge: dynamic thresholds and min / max
  • Gauge: conditional icons displaying
  • Gauge: reversed direction
How to use
  1. Create a new panel and select Chartwerk as the visualization
  2. Add queries with unique aliases
  3. Go to the Options Tab and setup panel:
  • Choose visualization type
  • Select metric in the Value -> Metric dropdown (by default, the first metric is used)
Options [Gauge]
  • Visualization:
    • Pod: option to select chart type
  • Value:
    • Metric: select metric query from dropdown
  • Extemum:
    • Min:
      • type number for static minimum value OR
      • enable "Use metric" toggle switch to select metric as minimun
      • default value: 0
    • Max:
      • type number for static maximum OR
      • enable "Use metric" toggle switch to select metric as maximum
      • default value: maximum of metric query
Demo
see demo
Installing Chartwerk on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Chartwerk from the commandline:
grafana-cli plugins install
Changelog
0.5.1
Added
  • Gauge: Additional Metric
Fixed
  • Repeatable option link issue
  • Bar-pod hover error
