title: "Chartwerk panel plugin for Grafana"
description: "Chartwerk panel with extended chart customization. Chartwerk panel plugin for Grafana by corpglory. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/corpglory-chartwerk-panel/
# Chartwerk
- Developer: corpglory
- Version: 0.5.1
- [Installation](https://grafana.com/grafana/plugins/corpglory-chartwerk-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/corpglory-chartwerk-panel/changelog.md)
![Main](https://grafana.com/api/plugins/corpglory-chartwerk-panel/versions/0.5.1/images/assets/img/gauge.png)
# Grafana Chartwerk Panel (beta)
![](https://code.corpglory.net/chartwerk/grafana-chartwerk-panel/raw/branch/main/src/assets/logo.svg)
**Grafana Chartwerk Panel** renders metrics using Chartwerk libraries. For now, it can render as Gauge. We are working on adding new visualizations.
![image](https://code.corpglory.net/chartwerk/grafana-chartwerk-panel/raw/branch/main/src/assets/img/gauge.png)
## Features
- 3 types of visualizations:
  - Gauge
  - Line Chart (coming soon)
  - Bar Chart (coming soon)
- Gauge: dynamic thresholds and min / max
- Gauge: conditional icons displaying
- Gauge: reversed direction
## How to use
1. Create a new panel and select Chartwerk as the visualization
2. Add queries with unique aliases
3. Go to the Options Tab and setup panel:
- Choose visualization type
- Select metric in the Value -> Metric dropdown (by default, the first metric is used)
## Options \[Gauge]
- Visualization:
  - Pod: option to select chart type
- Value:
  - Metric: select metric query from dropdown
- Extemum:
  - Min:
    - type number for static minimum value OR
    - enable "Use metric" toggle switch to select metric as minimun
    - default value: 0
  - Max:
    - type number for static maximum OR
    - enable "Use metric" toggle switch to select metric as maximum
    - default value: maximum of metric query
## Demo
see [demo](https://grafana.corpglory.com/d/8vGyMypGz/demo-home?orgId=4)
