Plugins 〉Finnhub
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Finnhub
- Overview
- Installation
- Change log
- Related content
Data Source Grafana plugin for Finnhub.
Before starting, it's necessary to get an API token from Finnhub and paste it to the "API Token" field in the plugin settings.
Currently supported queries:
Free API
Premium API
A sample dashboard provisioning file is available at provision/dashboard.json
. Read more about dashboards provisioning.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Finnhub on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Finnhub from the commandline:
grafana-cli plugins install
2. Configure the Data Source
0.6.0
- Add support for
$symbol
variable
0.5.0
- Remove @grafana/ui Form usage
- Update React to v.18
- Remove unused dependencies
0.4.1
- Remove
grafanaVersion
fromplugin.json
- Update
grafanaDependency
inplugin.json
0.4.0
- Update the plugin to be compatible with Grafana 10
0.3.2
- Update dependencies
0.3.1
- Restore trades endpoint (websocket)
0.3.0
- Store API token in secure field
- Temporarily disabled trades websocket endpoint due to proxy auth issue (quote query with dashboard refresh can be used as a workaround).
0.2.1
- Update the plugin to be compatible with Grafana 8
- Add social sentiment endpoint support
0.1.1
- Initial release
